Poll
Progressive Front Suspension Springs vs Stock Suspension Springs for CB550?
4 (100%)
0 (0%)
Total Members Voted: 4
Author Topic: Progressive Front Suspension Springs vs Stock Suspension Springs?  (Read 712 times)
Offline neurotoxin312
« on: September 26, 2014, 11:31:41 PM »
I am trying to decided if progressive front suspension springs for a Honda CB550 is actually worth the $100 upgrade. What are your thoughts? Will there be a noticeable difference in handling? Going for a cafe racer build. Thanks guys!
Offline flatlander
Re: Progressive Front Suspension Springs vs Stock Suspension Springs?
« Reply #1 on: September 27, 2014, 12:48:33 AM »
if you're talking about replacing the old original springs with new progressive ones, by all means do it. get new seals as well. i did the same and the difference was huge.
if you try to decide between new progressive springs and new OEM ones i don't know, haven't made the comparison.
Offline Steve_K
« Reply #2 on: September 27, 2014, 06:59:35 AM »
I put them in my 73 750 and I like them.  I use 15w fork oil as the thinner oil doesnot control the fork very well.
If you want even better results, consider RaceTech Emulators with the correct rate springs from RT.
I have used them on Suzuki forks and I am very pleased with the result!
Steve
Steve_K
« Reply #3 on: September 27, 2014, 07:42:50 AM »
if you're talking about replacing the old original springs with new progressive ones, by all means do it. get new seals as well. i did the same...
+1
Offline Green1
« Reply #4 on: September 27, 2014, 01:59:56 PM »
Progressive springs will totally transform the way the bike handles.
Highly recommended the bike will feel planted and predictable don't forget the back anything is better than stock
Honda CB750K1 Valley Green Metallic
Honda CB750K1 Candy Gold
Aprilia Pegaso 650ie
Moto Guzzi 1200 Sport
