Hello new here
Hope I can get some help I here, my 79 cb650 starts good runs well in low and high rpm but once it's warmed up like after leaving a highway for a few miles and u slow down to an off ramp or to a stop sign it Boggs and sputters like it doesn't want to move and has a hard time idling, once I get it down the road and give it the gass it sounds terrible like it's bogging down and not wanting to catch then it catches and pulls hard and is back to normal for a while.
I checked the carbs they are clean, jets slow and main are clean, the bike worked great until a few weeks ago, I replaced the plugs, and checked them they are golden brown on the tip but black on the threads, the bike also backfires when you decelerate from higher speeds. It backfires out the pipes but I think it also fires into the carbs as I noticed black marks on the carb cylinders that hold your needle.
Any ideas as to what the heck is going on, it's jetting is stock same as the air box, the only thing I can think of is it has a few wholes where the exhaust/header meet.
Could it just be running lean? Please help???
