Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Just tell them it is Barnes of flattrack bolt circle,and check your bolt circle.. And hole size Should be standard knock off pattern, ..but your bolt size is likely 5/16.Lots of used drag race on ebay, often your pattern, and some flattrack. What size do you need? Pitch ?
Now THAT is one Way Cool CBX. Having been fortunate enough to have owned a CBX, would be Awesome to still have mine and one like This, sitting next to it!
Sprocket Specialist's out in Oroville,CA. can make you up a sprocket.
Would sure be nice to have someone do a video of you going by shifting from 1st to 2nd !
Quote from: grcamna2 on October 30, 2016, 06:27:46 AMSprocket Specialist's out in Oroville,CA. can make you up a sprocket.
Quote from: grcamna2 on October 31, 2016, 06:39:54 PMQuote from: grcamna2 on October 30, 2016, 06:27:46 AMSprocket Specialist's out in Oroville,CA. can make you up a sprocket.Do they make these ? http://www.ebay.com/itm/630-38-tooth-Sertco-torsion-rear-sprocket-gear-six-bolt-dragbike-RC-Comp-Kosman-/121549883745
Quote from: Gearheadgreg on October 31, 2016, 06:44:59 PMQuote from: grcamna2 on October 31, 2016, 06:39:54 PMQuote from: grcamna2 on October 30, 2016, 06:27:46 AMSprocket Specialist's out in Oroville,CA. can make you up a sprocket.Do they make these ? http://www.ebay.com/itm/630-38-tooth-Sertco-torsion-rear-sprocket-gear-six-bolt-dragbike-RC-Comp-Kosman-/121549883745Greg,Give the dudes a call at 1-800-782-8200
A little off topic, maybe: I'm in need of some 24 valve shims for a CBX head just rebuilt (all the valves seats were rused, and the valves, from sitting outside 25 years with pod air filters... ). So, it needs 24 thinner shims: does anyone have some leftovers they might wish to sell? I'm still measuring to see what sizes it needs, but it seems to be all 24, now...
