Author Topic: "Crack" in engine case  (Read 597 times)
Offline theslayedsaint
« on: October 01, 2014, 08:59:10 AM »
Hey guys,
So after months of buying parts I'm almost ready to put my CB750 back togther..
When I notice the wear in the bottom half of my case. Could you guys please tell me how bad this is? I'm hoping its just some bad wear from the gears. Any thoughts would be great!
1974 CB750 custom build cafe racer
-849cc big bore
-Webcam 63a
-APE rods
-4-1 stainless exhaust
-GSXR front end
Offline lrutt
Re: "Crack" in engine case
« Reply #1 on: October 01, 2014, 09:08:41 AM »
can't zoom in on the image.
Offline iron_worker
« Reply #2 on: October 01, 2014, 09:31:00 AM »
I don't see any cracks. Are you talking about the rub marks from the chain? If so, this probably just means it's time for a new primary chain or timing chain /tensioner (I can't tell where I'm really looking at in the case). That piece where the aluminum has flaked off in the surface is probably just a casting defect and I don't think it will affect the strength enough to be a concern.
*edit* I see now this is the final drive area so probably time for a new primary chain. *edit*
IW
« Last Edit: October 01, 2014, 09:33:40 AM by iron_worker »
« Reply #3 on: October 01, 2014, 10:21:08 AM »
Looks like a bit of corrosion to me,unless you mean another area.
« Reply #4 on: October 01, 2014, 10:26:44 AM »
Maybe an arrow made with a sharpie pointing at it?
« Reply #5 on: October 01, 2014, 12:54:55 PM »
Casting boo boo. Nothing to worry about as long as what you are referring to is that little divot.
« Reply #6 on: October 01, 2014, 03:33:09 PM »
Yes sorry I didn't mean to say crack, it does look more like corrosion. Or some type of rubbing of the chain.The engine is getting overhauled and new chains, so sounds like I'll be ok. thanks for the fast replies.
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
