Colors don't matter, blue, yellow, pink or purple... What does matter is: the stock "blue" wire serves the coil for 1/4 and the stock "yellow" wire serves 2/3. This provides accurate timing fire of the coils.
But you still have to resolve the 12v issue. Even if you had the coil signal wires (blue, yellow, pink, green) reversed, you'd have spark, but crappy timing. Look for the BLK/WHT.
Prokops point was that he uses the stock KILL switch inline with the pamco successfully to interrupt the ignition via the KILL switch for safety, as you should. But, in order for your coils to fire, the KILL switch must be on, and if you've used the stock BLK/WHT scheme, then it must be carrying 12v to the coils.
