Author Topic: Senior project for high school - 78 CB750K  (Read 169517 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Senior project for high school - 78 CB750K
« Reply #700 on: February 20, 2015, 10:24:30 am »
According to the parts fiche:
http://www.servicehondapsn.com/fiche_section_detail.asp?section=2451919&category=Motorcycles&make=Honda&year=1978&fveh=131106
The brake rod is indeed oriented correctly, you just need to rotate the brake pedal pivot 180 degrees.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Restoration Fan
  • My wife will never call me
« Reply #701 on: February 20, 2015, 10:37:59 am »
Thanks for checking on that.  We still need to pull it back out and insert the spring between the pivot and the frame.  We forgot that before.
This time, we will rotate the angle 180 degrees.  :)
Offline Bill/BentON Racing
    • BentON Racing
« Reply #702 on: February 20, 2015, 11:25:14 am »
Carbs are fun too!!  It really is starting to come together, you should be proud, Bill
BentON Racing Website
BentON Racing Facebook
« Reply #703 on: February 24, 2015, 09:55:41 am »
The spring that goes onto the rear brake pedal.  Is that on the outside of the frame...between the frame and the pedal?  Or is it on the interior of the frame, near the swing arm?
Offline martin_uk
  • CB750F1 CB750K8
« Reply #704 on: February 24, 2015, 10:04:26 am »
Sounds like it has been covered, but pics may help as I am restoring a K8 too.
2015_0112frame0020 by nitram2010, on Flickr
CB750F1, CB750K8,  Triumph Street Triple R, AJS 350, Triumph 3TA
Offline martin_uk
  • CB750F1 CB750K8
« Reply #705 on: February 24, 2015, 10:10:17 am »
Here is a before shot, note the position of the brake rod to clear swinging arm
001 by nitram2010, on Flickr
« Reply #706 on: February 24, 2015, 10:10:52 am »
PERFECT!  Thank you for the pic.  That's what I was missing was how it linked up.
« Reply #707 on: February 24, 2015, 10:13:32 am »
Yeah, we had that explained to us before and took the swing arm off to correct it.  Oh well, so we remove it one more time.  No big deal because we're getting to be experts at taking the swingarm off and putting it back on.
 :P
Thank you very much for the photos.  I'm finding that, while I THOUGHT I had taken enough photos, I really didn't take enough photos in certain places where I needed to take more detailed photos.
Offline martin_uk
  • CB750F1 CB750K8
« Reply #708 on: February 24, 2015, 10:19:24 am »
 :P
I am not certain but you may be able to reposition the brake arm without removing swinging arm, by sliding inwards
Give me a shout if you need other pics, although mine was partially dismantled when I got it as a US import into UK
2014_1206Kparts20062 by nitram2010, on Flickr
Offline martin_uk
  • CB750F1 CB750K8
« Reply #709 on: February 24, 2015, 10:22:36 am »
Did someone let you know, the bent wire shaped piece is the carb overflow pipes guide and fits to right side centre stand pivot clamp and the plate fits to inside of frame by brake arm
« Reply #710 on: February 24, 2015, 10:26:01 am »
They did.  Wilbur told us in a previous post and we actually installed that last night.
We put the breather on beneath the battery box and figured out where all 3 of the tubes go last night.  Then we mounted the tube and tube clamp onto the frame before we put the swingarm back in.  Only afterward did I begin to question whether or not we really should have also done the spring.
No big deal.  We'll get it tonight once I get home from my dinner meeting.
Thanks again for the photos!
Offline martin_uk
  • CB750F1 CB750K8
« Reply #711 on: February 24, 2015, 10:30:48 am »
Have you fitted the centre stand yet?, as its much easier before the swinging arm goes on as you can attach the spring and plate, then slide in pivot with stand angled much higher than with swinging arm in situ and less spring tension, saves having to pack out spring with washers or trying to stretch to fit
« Reply #712 on: February 24, 2015, 11:40:23 am »
Yes.  Center stand was a piece of cake to fit without the swing arm on.
However, it does make dealing with the swing arm more of an issue because you have to hold the center stand down a bit to keep it out of the way.  Once we get the final two pieces we need (o-ring for front wheel and small, metal brake cap for the rear wheel), we can get the wheels on the bike permanently and remove the bike from the lift where it is right now.  Those are scheduled to arrive Friday.
    • BentON Racing
« Reply #713 on: February 24, 2015, 04:13:04 pm »
And then we get to play Carb party!  ;D Once again....all in the manual! Haha Good to see y'all back on it, Bill
« Reply #714 on: February 24, 2015, 06:54:52 pm »
Thanks, Bill!  And you can most definitely expect a visit when it's carb party time! :)
We haven't actually stopped yet.  I just haven't been posting updates because we keep having to redo stuff.  LOL, we've taken that swing arm off 5 times now.  The next one will be 6.  Had planned to do it tonight but I literally just walked in the door from work and have to be in a meeting all day tomorrow so it likely won't happen until later tomorrow evening.
The good news is that the pile of parts on the shelf is shrinking and the pile of parts on the bike is growing.  So, little by little, we're getting there.
By the way, THANK YOU, THANK YOU, THANK YOU for loaning us that master cylinder circlip tool.  Made getting the circlip out a piece of cake.  Got all the pieces out and cleaned the master cylinder.  Got 3 coats of black paint on it today and the final coat is drying right now.  Should be able to rebuild the MC tomorrow evening and get it on the bike.
« Reply #715 on: February 25, 2015, 04:50:26 pm »
OK...so when you're rebuilding the master cylinder, what in the heck is the secret to getting this little rubber boot onto the piston?
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #716 on: February 25, 2015, 06:02:01 pm »
Ron,
I just did that last week (maybe 2).  Take some brake fluid on your pinky finger and wet the inside of that piece and then just kind of stretch it over the piston.  Make sure you get it on in the right direction.  If you don't get it seated properly over that little ridge, it won't fit into the Master Cylinder bore right.  Also, if I remember right (from a week or 2 ago) that piece goes on the easiest from the end opposite where it is sitting in the picture.
Keep Going! :)
Charlie
« Reply #717 on: February 25, 2015, 07:48:35 pm »
Charlie,
You're a pretty handy guy to have around sometimes!  ;)
Got it back on.  Master cylinder rebuilt.
Also, we finally figured out how to mount the new coils onto the frame and get those to fit.
Found the missing piece for the rear wheel so we'll be putting that back onto the bike at some time tomorrow morning.  Can't mount the front tire and lock it down for good until we get the delivery from PartZilla because we need that big O-ring.  I guess I've been spoiled by Amazon.  Order something...they ship that day or the next and you have it 2 days later.  I ordered from PartZilla early Monday morning (like 5 am) and thought, "Well, they're in Albany, Georgia so I might have the stuff in a day or two."  Even opted to pay the extra few bucks to have them send it via FedEx ground over USPS.  I finally get an email late Tuesday night saying "Your order is expected to ship on Thursday."  Seriously?  To quote the guys on NFL Today...."COME ON, MAN!"
Offline AintNoEasyWay
« Reply #718 on: February 26, 2015, 04:47:14 am »
Partzilla was great the first time I placed an order from them. I've ordered from them several times since because often they are the only supplier I can find for certain parts. Every time I've ordered since, there has been a delay with products on back order, which they often don't tell you til a few days after your order. The worst case I've had from them was going two weeks of waiting without hearing from them, having to call them only to be told that "the part will be sent out tomorrow", then receiving an email another few days later finally telling me the part sent.
Sorry for the rant, Ron. Just want to warn you about this. I know of other guys who have had similar experiences with them.
« Reply #719 on: February 26, 2015, 05:53:30 am »
No worries, Nate.  I had the same thought.
Either the parts are there or they're not.  If they're there...ship them out.  Waiting 3 days just to ship something is crazy slow in these days of internet shopping.  If they keep that up, they'll find it hard to keep people buying from them.
Offline Scotty J
« Reply #720 on: February 26, 2015, 05:59:22 am »
Subscribed.
1972 Honda CB750 Four
2010 BMW R1200 GSA
Offline calj737
  • I refuse...
« Reply #721 on: February 26, 2015, 10:20:30 am »
You got to have a little patience when dealing with 4o year old bits and pieces. Not many places stock everything for every model. You want overnight guaranteed delivery, gotta buy a 2013-2015 motorcycle and order from a dealer.
Just in time inventory is the way of things unless you're ordering new parts.
Offline Maurice
« Reply #722 on: February 26, 2015, 10:25:57 am »
Just be glad that they don't come back a week later with NLA... Don't ask.
Amazing progress so far. I am just disappointed that the coils bracket looks like sh*t ;)
Offline edwardmorris
  • Youngish
« Reply #723 on: February 26, 2015, 10:31:52 am »
................You want overnight guaranteed delivery, gotta buy a 2013-2015 motorcycle and order from a dealer..............
Not necessarily, at least not everywhere. I ordered something off a 2015 bike, took six bloody weeks before it arrived  >:( >:(
« Reply #724 on: February 26, 2015, 05:48:42 pm »
You meet the nicest people working on a Honda!  :)
Today, Logan and I got the chance to meet Mark (mark52) and his brother, Barry.  Mark had driven up from his home in Tallahassee to visit his brother for the weekend and to work some more on his 75 CB750, which is at Barry's house here in the suburbs of Atlanta.
Since they were going to be in the area, we offered to let them come over and see Stella and I get to go see Mark's 75 tomorrow as well.  We first met Mark on line as he is the one who so kindly sent us a sweet, pristine rear chrome fender for Stella.  He had purchased it for his bike and found out it didn't fit.  When he offered it, I tried to pay him for it but he refused.  So I at least got to buy him and his brother dinner tonight and we all 4 had a great time sitting there and talking.  As I said at the dinner table, one of the great things about this build is that Logan is getting to experience the genuine kindness and goodness of the other people on this board and learn life lessons from some of the people we have met.
While they were here, Mark helped us get the back wheel onto the bike since we were ready to do that part.
We did have an issue in that the rear axle and the bolt that go onto it don't seem to be wanting to mate easily.  I'm afraid of forcing it onto there too much for fear of cross-threading one or both.  Bill, do you have a tap and die set big enough to handle the rear axle and the corresponding nut that goes on it?
« Last Edit: February 26, 2015, 05:59:39 pm by Restoration Fan »
