Author Topic: My 1974 CB550K -Brie! (First Build)  (Read 8265 times)
Offline igotalotofrice
« on: October 02, 2014, 08:23:49 AM »
I had this a couple of months now, but I think it's time to officially start a thread.  My goal is to get this bike running at tip top shape so I have something to ride while I build up my Triumph Bonneville.
Here is my bike the day I picked her up!
A little background on how I stumbled on this CB550.  I wrecked my Triumph this summer (I am fine) and now in the process of rebuilding it.  In the meantime I needed something to ride.
My barber knew I was into classic bikes and told me about his friend who inherited this CB from his uncle.  At the time I was somewhat interested, but I had my Bonneville.  Well after the wreck, I mentioned to him again that I was now looking for something else.  Lucky me, his friend is in the process of needing cash and wants to sell.
We set a time and went to look at the bike.  After the guy inherited the bike from his uncle, he only rode it a bit, I guess he was still new at it.  He decided to try to "cafe" it, but after he put on a Mac 4-1, he couldn't get it started and just left it in his shed for 3 years.  Minimal rust, nothing seized, and the bike only had 10,000 miles on it.
The bike as you can see, looks pretty good.  He wanted $1000 for it, I talked him down to $900 bucks. Also got 2 new tires he never put on with it!  I took it to my shop, empty out the old fuel from the tank and carburetors, found that the ignition wire was loose, put new fuel with Seafoam in it, hooked up a battery and got it to fire up!  After it was done shooting out nut shells from the muffler, me and a buddy got to work.
« Last Edit: October 02, 2014, 11:47:22 AM by igotalotofrice »
Re: My 1974 CB550K -Brie!
« Reply #1 on: October 02, 2014, 08:50:01 AM »
Alright, here is the progress so far.
Some goals right now:
-Get this thing running well
-Get thing thing to be able to stop well
-New lower seat ( I cannot reach the kickstand to kick it up!)
-General maintenance for a long life.
What came on the bike:
-Uni-filter for the airbox
-Mac 4-1 exhaust
-Everything else stock.
What I already did prior to the start of this thread:
-New clutch and throttle cables
-Carburetors rebuilt using rebuild kit (got it off 4-1, used everything in the kit)
-Bleed the front brakes
-New spark plugs
-New oil change and filter
-Fixed some of the wiring
-Valve adjustment
-Ignition timing (done at a Honda shop professionally)
-Frame check for integrity (Professionally, read some horror stories on here about bent frames)
-New tires on.
-Chain cleaned and lubed (dealer did that, it was nice of them.)
Things I still need to do:
-Got new brake pads and some SS brake lines for more stopping power.
-New steering head bearings, my are apparently shot.
-New seat or custom seat!!!!
-Check rear brakes and order stuff for that.
-Might be leaking air, got new airbox to carb boots.
Things that are wrong with it that I am currently working on:
-Bike idles, but I can't go any faster than mph.
-Clutch, I can shift to first and second without using my clutch lever, neutral a little hard to find.  Might need only a cable adjustment I hope.
Bike as I got it back from the dealer:
« Reply #2 on: October 02, 2014, 09:05:48 AM »
As I mentioned in my previous post, I am trying to get this bike running tip top.
Symptoms include:
-It idles.
-Won't go past 40 mph without struggle, seems hard to get higher speeds.
-I hear a "sucky, suctiony sounds" at idle.
-Will die when revved up and drop down in rpm's.
Here are what the spark plugs look like:
I orginally soak them in Simple Green and soda blasted them.  Then dipped then in vinegar to get rid of the soda and rebuilt them using a kit.
I amright now in the process of taking the carburetors apart again, on the advice of someone, to make sure the emulsifier tube(?) is clear.  I am using an ultrasonic cleaner this time with some water and dawn.
I noticed corrosion.
Everything still seals, but should I be worried in the near future?
Re: My 1974 CB550K -Brie! (First Build)
« Reply #3 on: October 20, 2014, 07:21:55 AM »
Short Update:
Got the carbs all nice and clean.  Took apart everything and just put it in the ultrasonic cleaner, and made sure all the nooks and crannies are clean.  Put back together and looks awesome!
Got 1/4 fuel lines, no filters ( fuel looks clear! Tank is clean.) and made sure I get a good amount of fuel flowing right.
Bench synced, put the carbs back on the bike, and use a vacuum sync to get the bike to idle at around 1,200 to 1,400 rpms!
No colored smoke out the tail pipe.
Running 89 octane fuel.
Now, during my test ride, i was able to get to 70 mph (by my speedo), but it responds well to 1/2 to 3/4 but getting a little hesitation at WOT.
My settings are the stock jetting using the aftermarket rebuild kit.  I am thinking of going to 105 mains, but want to buy them from jetsrus.  What do you guys think?
Offline gloken
« Reply #4 on: October 20, 2014, 08:23:18 AM »
Good call on cleaning the carbs the second time, I cleaned mine, and what I thought was "clean" was still far from perfect. The more you know.
This seems to be a really good walk through of the process next time you strip the things apart.
If you have no power in gear I'd blame the clutch cable and adjustment first. I'm no expert, but I'm at about the same stage as you, and that was my experience.
'77 Honda CB550K
'84 Honda V45 Sabre 750
Offline Tews19
  • I am no
« Reply #5 on: October 20, 2014, 10:45:27 AM »
Great buy! I always love the orange tank and side covers! What the plan for a cafe seat? What's the condition of the seat on it now?
1970 Honda CB750 survivor.
« Reply #6 on: October 27, 2014, 09:24:42 AM »
Awesome, I have a spare set of carbs I want to rebuild. This will come in handy.
« Reply #7 on: October 27, 2014, 09:32:41 AM »
Update 10.27.2014:
- Cleaned out my petcock and re-did my fuel lines!  Seems like there was sediment in the petcock, impeding the fuel flow.  Got that sorted out!
-New Uni-Filter, old one was falling apart.
-New plugs in, but still carbon build up on them.
-Got a new seat, still need to upholster it and put it one.  Thanks Tews for it!  One less thing to worry about.
Things that I have to sort out:
-New plugs show carbon fouled.- Research shows too rich, plugs not hot enough?
-Cylinder 1 is cooler then the others, 2,3,4 are fine: Bad spark plug wire?  Coils going bad?
-Hesitation at WOT and higher speeds, flat spot at around 5k rpms- I don't know, too rich?
-I can shift w/o using my clutch lever
I am going to re-run the carb vacuum gauge to see if they are still balanced then move my fuel/air adjuster to 2 full turns from 1.5 turns. Does anyone have any advice?
« Last Edit: October 27, 2014, 09:38:46 AM by igotalotofrice »
Offline Tews19
  • I am no
« Reply #8 on: October 27, 2014, 10:25:56 AM »
550s have a flat spot. Usually around 3800-4200 from my own experience.  Did you check the needle position on the carbs? Sometimes PO will adjust those; hence possible reason for running  rich. Is cylinder one getting intermittent spark?  Easy way to check is to use a spare plug and test with it touching the engine case itself.
« Reply #9 on: October 27, 2014, 10:55:29 AM »
I am going to check the spark on cylinder 1 tomorrow evening.  I rebuild the carbs, I used an aftermarket needle from a rebuild kit and made sure it was on the stock position.
The real issue I think is at WOT.  It chokes and sputters, when I do it.
Offline Tews19
  • I am no
« Reply #10 on: October 27, 2014, 10:58:36 AM »
How come you changed out the original brass in the carbs? The "new" brass is kits isn't up to the quality of the original. If you have them maybe swap back?
Side note on the seat. Move it back till the hump hits the frame. It will fit better.
« Reply #11 on: October 27, 2014, 11:06:05 AM »
I guess I have to put the original brass back in....I have them clean and what not, so no biggie.  Maybe I can do that without having to take my carbs off the bike.
As for the seat, Thanks for the tip!  I was just checking to see what it looks like.  I gotta remove the rear fender and the mud guard for a proper fit.
Offline Tews19
  • I am no
« Reply #12 on: October 27, 2014, 11:11:40 AM »
Yeah fender off and it will slide right on. The brass maybe able to go back on without removing but it literally takes 5 min to remove the carbs.
Not sure if you know the non knuckle busting method but here it is.
Remove the 2 bolts for the battery box. Remove the battery box.
Next remove the back side of the airbox.
Now take off the carb to airbox metal clamps. Got to take them off completely to prevent any damage. Then slide the half box that connects to the CARB down as far as it can go... carbs will come out fairly easy that way. No damage and no bloody knuckles!
« Reply #13 on: October 27, 2014, 11:15:50 AM »
It's exactly what I do!  I have tiny hands so that also works to my advantage, especially when I have to stick my hand in the airbox to make sure the boots are on correctly!
Offline gloken
« Reply #14 on: October 27, 2014, 12:42:36 PM »
Yuck, I learned that one the hard way. So much swearing and bleeding.
'77 Honda CB550K
Offline Slinky
« Reply #15 on: October 27, 2014, 06:33:19 PM »
Hey man where did ya pick up that seat pan? Looks awesome. Also do you still have the factory seat!! For sale?
Offline Tews19
  • I am no
« Reply #16 on: October 27, 2014, 07:22:56 PM »
Slinky- The seat is from Bedlam Werks but he got it off me..
Offline Slinky
« Reply #17 on: October 27, 2014, 07:41:42 PM »
Got any more ;)
Offline Tews19
  • I am no
« Reply #18 on: October 27, 2014, 08:06:20 PM »
No I bought it new. Never used it so gave a forum member a smoking deal as I know he will put it to good use.
« Reply #19 on: October 28, 2014, 09:53:59 AM »
Yup, Bedlam werks, Tews provided everything for me.  As for the original seat, I still have it, but Tews gots dibs on it if I sell it.
I"ll let you know if things change.
Offline Tews19
  • I am no
« Reply #20 on: October 28, 2014, 10:05:36 AM »
Quick note on the seat. The grommets go on the bottom of the seat itself. That will support on the frame. I put it on the pan I believe.
« Reply #21 on: October 28, 2014, 10:08:43 AM »
Yup! Grommets on the seat, the seat pan has nothing on it!  Thanks for the heads up!
« Reply #22 on: October 29, 2014, 05:16:48 PM »
Update 10.29.2014
My stock mains and jets are not in good condition, so I am going to buy the OEM from jetsrus.  Hopefully they are exact replacements.  The needle on the other hand, looks pretty good.  I am sticking with stock settings.
I also got a set of Dyna coils 5ohm for $50, my buddy sold them to me:
More to come....
« Last Edit: October 29, 2014, 05:18:37 PM by igotalotofrice »
Offline Tews19
  • I am no
« Reply #23 on: October 29, 2014, 05:19:22 PM »
Can you take a pic of the jets? You will be surprised. Only really need new o rings.
« Last Edit: October 29, 2014, 05:24:42 PM by Tews19 »
« Reply #24 on: October 29, 2014, 06:02:18 PM »
1 of them is destroyed, I figured I'd just get new ones.
Got these main jets ordered: http://www.jetsrus.com/a_jet_kit_street/honda_550_CB550K_1974-1976.htm
