Author Topic: 276mm Rotor On CB750 hub  (Read 1895 times)
Offline PPG9944
« on: October 02, 2014, 06:47:14 PM »
Does anyone know what brake rotors that have a diameter of around 275 or 276mm with the same bolt pattern as the stock front hub on a cb750?  I believe i measured the bolt pattern to be about 80mm.
Online scottly
Re: 276mm Rotor On CB750 hub
« Reply #1 on: October 02, 2014, 07:09:19 PM »
A 550 275mm rotor will bolt directly onto a 750 K hub. Later 750 F's are a different animal. ;)
« Reply #2 on: October 02, 2014, 08:26:02 PM »
Ducati and Yamaha rotors fit..  Different center hole size..
« Reply #3 on: October 02, 2014, 08:51:23 PM »
For reference, what size is stock 750K?
Offline MiGhost
  • What was that about being an
« Reply #4 on: October 02, 2014, 08:57:45 PM »
HONDA CB750 1969-76 K1-K6
HONDA CB750 1977-78 K7-K8
HONDA CB750A  1976-78
Dimensions      (mm)
Outside Diameter   296
Inside Diameter      154 (disc only with mounting flange)
Bolt Hole Circumference   166
Bolt Hole Quantity   9
Bolt Hole Size      6.5
Thickness      7.0
Minimum Thickness   6.0
Offset         0.0
Type of Bolt Holes   STRAIGHT
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
« Reply #5 on: October 03, 2014, 07:50:53 AM »
Ebc make a floater that fits.
Offline Oldtech
  • Motorcycle tech: old, cranky and retired
« Reply #6 on: October 04, 2014, 05:31:57 AM »
754, do you have an EBC part number? I've checked a few sources and can't find one.
« Reply #7 on: October 04, 2014, 07:36:52 AM »
I don't but far as I know they made them for some of the fours. My buddy has the catalog but won't see him till next week.
Offline PPG9944
« Reply #8 on: October 16, 2014, 05:15:04 PM »
I actually ran into a gentleman that does brake rotors.  Turns out stock cb550 rotors are about the diameter im going to need.  He drills and narrows the rotors to about a 5mm thickness which is also what I need.  May go that route
« Reply #9 on: October 16, 2014, 05:28:27 PM »
I think the EBC rotor only fits 77-78K and all Fs. OCICBW
