Author Topic: rc 315 and org timing card  (Read 2501 times)
Offline BPellerine
« on: October 03, 2014, 03:39:44 PM »
kinda neat came all the way from texas.bill
1978 CB 750K ard and webers
another anfob
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Re: rc 315 and org timing card
« Reply #1 on: October 03, 2014, 04:18:30 PM »
is it for sale? put me in line pending price
Offline BPellerine
« Reply #2 on: October 03, 2014, 04:21:34 PM »
no it is not for sale it took a lot of luck for me to get it.bill
another anfob
Offline TurboD
« Reply #3 on: October 03, 2014, 04:31:44 PM »
Isn't the Dynoman DP315 the same grind?
Offline BPellerine
« Reply #4 on: October 03, 2014, 04:38:50 PM »
don't know for sure but I wanted the orig.bill
another anfob
« Reply #5 on: October 03, 2014, 04:40:29 PM »
Good timing Bill, I have the 315 timing card right in front of me... ;D ;)  Can you write out those specs Bill, I can barely read them but mine seem to differ to yours, could be because its hard to read..?
My specs RC 315
Intake        Exhaust
Opens 23 B.T.D.C                                                               Opens 53 Before B.D.C
Closes 53 After B.D.C                                                        Closes 23 After T.D.C
Lift 365        Lift 365
Running clearance 012                                                      Running clearance 012 cold
Duration 310        Duration 310
« Last Edit: October 03, 2014, 04:42:56 PM by Retro Rocket »
Offline TurboD
« Reply #6 on: October 03, 2014, 04:41:15 PM »
I understand that. I have a RC454 if your interested.  ;D
« Reply #7 on: October 03, 2014, 04:55:45 PM »
Here's a scan of mine Bill...
« Reply #8 on: October 03, 2014, 06:01:27 PM »
I gotta get back home and check that against my Yoshimura Daytona sheet. Those numbers look real familiar. More duration?
« Reply #9 on: October 03, 2014, 06:02:56 PM »
I was struggling to read Bills Jerry, but i think you are correct.... ;)
Offline BPellerine
« Reply #10 on: October 03, 2014, 07:30:00 PM »
here is what mine reads rc 315 b meaning billet I guess, yours says 315 no b
intake opens 12 deg btdc
closes 42 deg
lift .358
running clearance .012
duration 234
exhaust opens 42 deg bdc
closes 12 deg after tdc
lift .358
running clearance.012 cold
duration 234
this is an original 315 taken out of an 836 weber carbed engine with branch head built around 1975
hope this helps.bill
« Last Edit: October 03, 2014, 08:02:27 PM by BPellerine »
another anfob
« Reply #11 on: October 03, 2014, 09:49:32 PM »
My 315 card is about the size of a pack of smokes.... I dont have the sheet..
« Reply #12 on: October 03, 2014, 09:55:57 PM »
From Axl's (RIP) site
Russ Collins Cams
Russ Collins made several cams for the 750 SOHC/4 engine:
                Durat                                                   In o/c
        Valve   ion   Lobe    Over                                      Ex o/c
Cam #   Lift    @.04" center  lap                                       btc/abc
        inches  degr  degr    degr   Description and Application        btc/atc
RC295                                Torque cam
RC295                                Racer cam
RC315   .365    310   104            Hot racer cam, very good for heavy
                                     street and altered race bikes
RC327   .370    270           94     Full competition cam               34/56
        30/60
And........
Yoshimura Cams
Yoshimura used to make different cams for the 750. Unfortunately, these have been discontinued years ago.
                Durat                                            In o/c   Run-
        Valve   ion   Lobe                                       Ex o/c   ning
Cam     Lift    @.04" center                                     btc/abc  clrnc
        inches  degr  degr    Description and Application        bbc/atc  inches
Daytona .392    256           Must use Yoshimura valve springs   23/53     .004
Race    .360    256                                              53/23     .004
Road &  .378    252                                              20/52     .004
Track   .341    244                                              46/18     .004
Stage 1 .362    253   105                                        21.5/51.5 .006
        .330    244   105                                        47/17     .006
Stage 2 .383    256   105                                        23/53     .006
        .339    256   105                                        53/23     .006
Isle Of .354    264           Must use Yoshimura valve springs   27/57     .004
Man Race.337                                                     56/27     .004
For racing applications, add .002" clearance
« Reply #13 on: October 03, 2014, 09:59:09 PM »
Those open close numbers don't equal 310 degrees duration? I get 256?? Just like the Yosh Daytona duration
Offline TurboD
« Reply #14 on: October 03, 2014, 10:05:46 PM »
The open close numbers are at .050, not the true actual open close.
« Reply #15 on: October 04, 2014, 01:53:09 AM »
Thats exactly what mine says Jerry. Its definitely a 315, I even have the original receipt for it... ;D ;)
It was bought around 1979- 1980, i'll check the receipts next time i have them out for a date... ;)
Bill, they were all billet cams mate, says it on the installation sheet that is part of the paperwork, looks like the later ones were a little hotter. Mine came out of a methanol run drag bike.... ;)
« Reply #16 on: October 04, 2014, 09:26:46 AM »
RC duration based on lift 23/53, 53/23 is 256°/256°  @0.05"lift (1.25mm).  310°  must be total duration.
My old Action Fours SS-1 cam (was said to be for people affraid of hot cams). Data when I timed it last time:
Not that much less: 21/53, 54/22° @ 0.04"lift (1.0mm)   Duration 254°/256°
IN/EX 0.361"lift (9.18mm)  (.360 in spec)
I do not know how much it will differ in duration during the difference in lift 0.01" (0.25mm). I can imagine that the cam is rather agressive here and therefore not much in °  versus lift.
RC315 must therefore be a good cam and streetable when my cam I compare with is very streetable, smooth idle (when carbs are right) and good for touring.
RC315 will be on my list too :)
RC315 Dyno chart soon?
The cold season is here where I live and an obstacle for my plans. I'm waiting for jets.
After that book Dyno test for my actual cam, Action Fours SS-1 cam. Then change to CX-7, Dyno again and finally my latest cam Megacycle 125-20(25) Dyno for this too. Frame kit make all this fun possible. I plan to publish the results in the forum thread for cams and Dynos.
« Last Edit: July 16, 2015, 11:46:44 PM by PeWe »
Offline BPellerine
« Reply #17 on: October 04, 2014, 09:34:36 AM »
the reason I wanted this cam is bcause it does run on the street with the setup I have ,got mine from greenjeans who had the orig build sheet for the ko engine this is the second engine I have heard of with almost identical components the other being 754s so it does work.funny thing is that the engine did not have an adj sprocket  and was not slotted????bill
another anfob
« Reply #18 on: October 04, 2014, 09:44:44 AM »
closes 42 deg
lift .358
duration 234
lift .358
duration 234
Really RC315? The data is very mild in both duration and lift.  Data @ 0.05"lift?
RC had a funny sprocket with fixed holes for different advance, right? Possible to turn sprocket the other way too.
Offline kmb69
« Reply #19 on: October 04, 2014, 12:15:58 PM »
Sending you a PM on that RC454.
Offline BPellerine
« Reply #20 on: October 04, 2014, 05:05:19 PM »
rc did produce a 5/0/8 sprocket that you could move to change cam time but my 315 was installed with the stock Honda sprocket ,I have a cyclex adj sprocket for install.bill
another anfob
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #21 on: October 05, 2014, 07:56:47 AM »
It's easy to DIY slot the cam sprocket, very little filing/grinding will be required, that slot doesn't have to open very much! With good cylinder pressure and proper jetting, the 315 was a great hot rod cam and I tore up the streets for a long time running with one. NO problem pulling redline+ in any gear.  ::)
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Offline BPellerine
« Reply #22 on: October 05, 2014, 09:16:46 AM »
that is great to hear nitro as mine bike will be as hot rod as I know how to make it while still driveable.bill
another anfob
