Author Topic: Will a cb750c tank fit cb500?  (Read 618 times)
Offline Moosey
« on: October 04, 2014, 01:20:11 AM »
Will a 80, 81 cb750c tank fit a 71 cb500?
Offline Moosey
Re: Will a cb750c tank fit cb500?
« Reply #1 on: October 04, 2014, 09:08:50 AM »
bump
« Reply #2 on: October 04, 2014, 09:23:41 AM »
Depends on how badly you want it to.
« Reply #3 on: October 04, 2014, 01:53:49 PM »
I'm thinking it won't fall directly into place but I'm not sure of that. It seems like I saw a pic of one on a sohc  750, if that helps.
Offline BPellerine
« Reply #4 on: October 04, 2014, 05:40:07 PM »
I put one on a 750 to see how it would look but changed my mind ,fit on good though,cant see why it wont fit a 550 other than size.bill
1978 CB 750K ard and webers
another anfob
Offline Moosey
« Reply #5 on: October 05, 2014, 12:42:57 PM »
Thanks for the replys!
Offline Moosey
« Reply #6 on: October 07, 2014, 06:24:03 PM »
Will the tunnel in the 750c tank fit on the 500 backbone. Is the tunnel wide enough?
« Reply #7 on: October 07, 2014, 06:27:33 PM »
If you've seen the frame on the later Honda's you will know why the tanks fit easily on the older bikes, you will have a mile of room under a later tank on a 500-550 because those little honda's don't have the extra side rails under the tank...
