Author Topic: Rear wheel cracked brake lining  (Read 683 times)
Offline crantonr
« on: October 07, 2014, 07:44:22 AM »
The rear brake oscillates when applied under load which has led to my CB500 failing its UK road test. On inspection there is a high point on the brake drum which has been caused by a crack in the lining. I guess my question is do I try and get the drum re-lined or try and pick up a replacement on Ebay?
Cheers
Richard
Offline mickwinf
Re: Rear wheel cracked brake lining
« Reply #1 on: October 07, 2014, 10:33:38 AM »
most used ones are also cracked so relining one would be best way. Are you on sohc.co.uk as there has been some threads about this subject and info on a man who can do it for you.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=lgk4m9rs5r89as68r3jkl51a84&/topic,60973.0.html
« Reply #2 on: October 07, 2014, 10:41:57 AM »
yes you can put the hub in a lathe..and turn the old drum aut,,and find a drun from a small car/auto trailer..turn it dovn to fit the hub..it must be heatet up and the kold drum put in as a schrenk fit..and some safty threads drilled in to fit som safty schrevs 3 or 4 to ekstra safe
i bayed a reserve hveel in germen e bay,,but it have almost same defekt...so be ekstra care baying used stuff...the old 550 hub fitts..but later 550 have a different brake plate..so go for a 500 for safty
my plan b..are to frit a small disc brake..and build a adapter to press in the old hub..but it are hard to find a small nice disc...750 f disc are as big as hell
« Last Edit: October 07, 2014, 10:50:10 AM by strynboen »
i hate all this v-w.... vords
Offline crantonr
« Reply #3 on: October 07, 2014, 11:12:40 AM »
Thanks guys for the responses. My fear was that a used wheel may not be any better. Can you give me a lead on thread about re-lining?
Thanks
Richard
« Reply #4 on: October 07, 2014, 12:57:46 PM »
Hey Richard.  There is a UK SOHC4 site.  sister site.  Like this, it may have a parts for sale section.
Members in your area might do you a solid and hook you up with a good, useable hub.
