Author Topic: shifter seal  (Read 2700 times)
Offline jtb
  • An unlikely
shifter seal
« on: October 02, 2006, 10:08:02 AM »
I guess I buggered my NEW shifter seal when I installed it. ??? ??? :-[  It leaks when the bike is on the side stand.  When my new NEW seal comes in, what is the best way to install it?
1.  Take the tranny cover off, install the seal, and replace the cover,
                                              -OR-
2.  Install the seal with the tranny cover in place?
Thanks,
John
1977 CB750F
1985 V65 Sabre
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
Re: shifter seal
« Reply #1 on: October 02, 2006, 10:43:14 AM »
FYI: after an epic battle replacing my shifter seal (but mine is a 550, not 750) I still had a very small leak.  I found my shifter seal to be OK, but there was a small leak from the oil pump (directly adjacent) that I never noticed with the Niagara Falls of oil eminating from the shifter.  You may want to check around a bit to make sure its not something else.
Here was my battle --> http://www.sohc4.us/forums/index.php?topic=8384.msg77571#msg77571
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: shifter seal
« Reply #2 on: October 02, 2006, 10:56:06 AM »
I concur. Clean everything in the vicinity off before assuming that your diagnosis is correct.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline OldSchool_IsCool
  • Really feeling like an
Re: shifter seal
« Reply #3 on: October 02, 2006, 11:08:53 AM »
Could just use the center stand.  ;D
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
Re: shifter seal
« Reply #4 on: October 02, 2006, 01:40:09 PM »
Had the same problem on my 500. I replaced that seal twice
and still it leaked. I found the problem nearly disappeared
after I switched to a good quality 4 stroke oil.
Bikes parked out front mean good chicken-fried steak inside.
Offline Steve F
Re: shifter seal
« Reply #5 on: October 02, 2006, 01:44:15 PM »
I recommend that you take a close look at the shifter shaft bushing.  Sometimes, the bushing gets worn or out-of-round in the inside diameter, and this will allow the shaft to move enough to open a gap around the seal lip.  Grab a hold of the shifter shaft, and see if you can wiggle it back and forth in the hole.  Replacing the bushing is no biggie, just getting the part you need may be the hard part.   >:(  You may need to replace the bushing BEFORE you attempt the NEW seal install.
Offline jtb
  • An unlikely
Re: shifter seal
« Reply #6 on: October 02, 2006, 02:24:58 PM »
Just looked at Parts Fish, and don't see a bushing listed for the 77 750F.  I know it's leaking from the seal, I've already done the clean up.  Also had a lead around the tach cable seal, but  it wasn't seated.  Just from looking at the shifter seal, I 'm 99% sure that it's buggered.  New one will be in by Friday.
1977 CB750F
1985 V65 Sabre
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
Re: shifter seal
« Reply #7 on: October 02, 2006, 02:31:32 PM »
I stumbled upon this trick last winter........AA MAG LITE housing..
« Last Edit: October 02, 2006, 02:37:43 PM by chippyfive50 »
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline nickjtc
Re: shifter seal
« Reply #8 on: October 02, 2006, 03:01:27 PM »
Very neat!
1977 Suzuki GS750
Offline jtb
  • An unlikely
Re: shifter seal
« Reply #9 on: October 02, 2006, 03:47:44 PM »
Thanks, Chippy!  I'll use it.
 8) 8) 8)
John
1977 CB750F
1985 V65 Sabre
Offline csendker
Re: shifter seal
« Reply #10 on: October 03, 2006, 09:57:05 AM »
An old set of handlebars that you never put away will work in a pinch too.  Keep in mind the job of the seal is to keep the oil inside the engine from coming out.  If you, as I did, change it with a full complement of oil (550=wet sump...), then all that oil will in fact try to get out, and quite successfully.  I panicked, put the seal on, grabbed some old bars I had left lying around and they fit like a charm.  Pushed it right into place with minimal spill.
Offline nickjtc
Re: shifter seal
« Reply #11 on: October 03, 2006, 10:05:51 AM »
You're a brave soul. Why didn't you drain the oil first?
1977 Suzuki GS750
Offline jtb
  • An unlikely
Re: shifter seal
« Reply #12 on: October 03, 2006, 06:56:27 PM »
Nick, the 750 is a dry sump, only enough oil to leak out if it's on the side stand, but I do have an extra set of bars, I'll check them against the seal.  Thanks,
John
1977 CB750F
1985 V65 Sabre
Offline csendker
Re: shifter seal
« Reply #13 on: October 04, 2006, 04:14:03 AM »
Because I'm an idiot.  Focusing on the task at hand, the ramifications just never dawned on me.  Duh.
Offline tsflstb
Re: shifter seal
« Reply #14 on: October 05, 2006, 07:36:41 AM »
On the subject of seals, I thought I'd just spread my experience with a cheap set ordered from http://www.crc2onlinecatalog.com/
I don't think there are any oil galleys in the shifter seal, but don't waste your time or money on these.  The output shaft seal I installed didn't have the correct holes to allow oil to lube my transmission.  I didn't know to look for it when I installed them.  Caused the bike to lock up solid at 60 mph.   :(
Buy the genuine Honda parts.  I saved $10 on seals and spent $500 in engine repairs, $100 for a new rear tire, and was lucky to not have any medical expenses to go along with that.  I've emailed Cycle-Recycle, but received no response.  They're still selling the crap seals.  Sorry to rant, but maybe I'll save someone else some problems.
will cause
Offline nickjtc
Re: shifter seal
« Reply #15 on: October 05, 2006, 10:35:20 AM »
Thanks for the heads-up.
1977 Suzuki GS750
Offline jtb
  • An unlikely
Re: shifter seal
« Reply #16 on: October 05, 2006, 06:06:13 PM »
Well, the seal was, in fact pretty buggered up.  Put the new one in tonight.  ($2.47 from the dealer)  I ended up using a deep 13/16" socket (read spark plug) it was perfect.  Now the bike is back on the side stand, we'll see if that stopped the leak.  :)
John
1977 CB750F
1985 V65 Sabre
Re: shifter seal
« Reply #17 on: October 05, 2006, 06:52:56 PM »
will cause
That sucks. i learned (a long time ago) use OEM.....period.
