Depends on your budget...............Frank's suggestion is workable if you are careful and consistent. Acquiring and then rebuilding a 410 head can be difficult and expensive
To improve the valve-reliefs................remove the pistons and measure the dome thickness to be sure there is sufficient metal remaining after milling to the desired depth. Assume gentle 'kissing' at this point............I would think you would want 20-thou or more of clearance...about 0.5mm.
If your cam is an F2 unit, you may be able to gain a good portion of the needed clearance with a stock K cam and only minor valve pocket machining. The difficult part of the valve-relief machining is expanding the perimeter of the relief in direct proportion to how the valve will 'fit' into the piston with ample clearance at the radial edge of the pocket.
I had been thinking what would be the advantage of using the K head on my F engine...
Cause I would probably have to be rebuilding part of this head as well and find a new cam + holders since they are garbage now...
I found a complete F2 head (minus one camholder thing, the half moon with the 2 bolts in it) for 90 bucks 20minutes from where I live...
and here is the part where I lost you (not that experienced with engine or engine specific english
minor valve pocket machining. The difficult part of the valve-relief machining is expanding the perimeter of the relief in direct proportion to how the valve will 'fit' into the piston with ample clearance at the radial edge of the pocket. don't get me wrong, I'm not being a pr*ck here.
Just want to make the right decision. using a K head where I have to buy a new cam and holders + milling on the pistons + the valves need lapping, skimming the head + cilinders?
or overhaul a (cheap) F2 head + skimming etc..
Money is not really a big issue since I wild spread this over the next few months, it's winter here anyways so no riding anyways and plenty of other projects ahead where I can make some money.
not that I'm a big spender but want to do it right the first time
