Author Topic: Bent Rear Shock  (Read 602 times)
Offline qw3rtie
Bent Rear Shock
« on: October 12, 2014, 09:04:18 AM »
I'm taking apart a 75' CB550F and noticed that the left rear shock is slightly bent. Is there anything I can do to fix this or should I just buy a new set? Thanks.
the bent shock
the right unbent shock for comparison
Re: Bent Rear Shock
« Reply #1 on: October 12, 2014, 10:27:17 AM »
Assuming they are 35 years old, I'd be shopping for a set of Hagons.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
Re: Bent Rear Shock
« Reply #2 on: October 12, 2014, 10:37:54 AM »
Looks like the damper rod is straight but the spring is out? Hard to tell. Either way, something is amiss and Stev-o is on the money I reckon.
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline Dunk
Re: Bent Rear Shock
« Reply #3 on: October 12, 2014, 02:00:46 PM »
I'd want to be sure the rod is actually bent. Spring could not be seated perfectly centered or can bow a little either side I suppose as nothing keeps it centered.
Offline calj737
  • I refuse...
Re: Bent Rear Shock
« Reply #4 on: October 13, 2014, 05:24:17 AM »
For kicks and giggles, verify the preload adjustment is the same on both shocks. Can't tell from the picture, but it does appear the left side is compressed tighter than the right...
But, I'm with the others, the springs look out more so than the rod/body.
Re: Bent Rear Shock
« Reply #5 on: October 13, 2014, 05:30:02 AM »
For giggles again did the bike ever have shock lowering brackets on the swinger ? Those can put some undue stress on shocks with the new angle.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=tsbg98r9lb6uijbr2b800g1606&/topic,60973.0.html
Re: Bent Rear Shock
« Reply #6 on: October 13, 2014, 08:26:05 AM »
try to turn the spring araund...it can be done by hand...and see if the spring are broken a bit off..it can make  imposibel to straighten the spring..
or schrev the top off.............and rooll the spring on a straight plate
i hate all this v-w.... vords
Offline Tews19
  • I am no
Re: Bent Rear Shock
« Reply #7 on: October 14, 2014, 01:25:59 PM »
I think Cal is right on. You notice one spring looks more compressed
1970 Honda CB750 survivor.
Re: Bent Rear Shock
« Reply #8 on: October 14, 2014, 04:16:06 PM »
PS- Honda did not use a big lock washer on the head of the lower mount bolt  ;)
