Support the site. Your contributions keep this site running.
Could you draw an arrow to the harness you are referring to? Can't work out what you mean
Why do you want to remove the white part?
Why do you want to remove the white part? It is part of the Switch. The harness plugs into it at right angles. The extended finger on the white hood is a release catch for the harness plug.
