Author Topic: RC distributor  (Read 1605 times)
Offline cbr954
RC distributor
« on: October 12, 2014, 02:33:53 pm »
Do all the RC distributor drive housings have the small hole in this picture?  Mine starts to leak oil after a short ride and it is coming from this hole.  Its definitely not the seal because I can see the oil trail from this vent hole when I pull the housing.  It goes all the way through into where the distributor goes into the housing.  I am assuming it is a vent to keep pressure from building up but it starts leaking oil after just a couple of miles.   I lowered the oil level a little bit also from spec just to see if it stopped but still leaks.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline sohc boy
Re: RC distributor
« Reply #1 on: October 12, 2014, 10:40:15 pm »
i have a RC, drive ,an yes, has a vent hole the same , yes ,i too get bit of oil leakage from it
i live by the voice inside my head
Offline cbr954
Re: RC distributor
« Reply #2 on: October 13, 2014, 06:08:36 pm »
Thanks.  I was hoping I could plug it off, guess it will have to sit on the shelf because it leaks oil and runs out onto the exhaust.
Offline jonnycakes
Re: RC distributor
« Reply #3 on: October 14, 2014, 04:23:54 pm »
I'll buy it back if your not gonna run it.
'Matic-Fanatic
Offline cbr954
Re: RC distributor
« Reply #4 on: October 14, 2014, 04:55:48 pm »
I am going to try some stuff with it.  I might decide to stick it on my drag bike.  I dont think it will leak in that short amount of run time.
Offline BPellerine
Re: RC distributor
« Reply #5 on: October 14, 2014, 05:31:43 pm »
is there any way to run a line from it upwards so that it does not come straight out?bill
1978 CB 750K ard and webers
another anfob
Offline cbr954
Re: RC distributor
« Reply #6 on: October 15, 2014, 05:45:39 pm »
Yeah I am going to do some looking and see how I could run a vent line up and out of the housing.
Offline jonnycakes
Re: RC distributor
« Reply #7 on: October 22, 2014, 03:14:24 pm »
i think the little spot of oil is worth the look
'Matic-Fanatic
Offline Bill/BentON Racing
    • BentON Racing
Re: RC distributor
« Reply #8 on: October 22, 2014, 04:01:37 pm »
I don't recall leaking being a problem.....been a long time though, blue72turbo runs one. They won't let you run if it's leaking oil and they see it!  ;D
BentON Racing Website
BentON Racing Facebook
Offline BLUE71TURBO
Re: RC distributor
« Reply #9 on: November 11, 2014, 07:17:06 pm »
              That's BLUE71TURBO !  HA HA !   I do not run a R.C.angle drive. I'm running a A.R.D. CDM  Magneto.  I do have a R.C angle drive for a
               KAWASAKI 900-1000 .  Mine has the small hole. It's for oil to get to the upper distributor drive or pressure relief i'm thinking. I don't see
               I don't see how yours is leaking. The hole should be sealed against the engine case.   ;)
Offline cbr954
Re: RC distributor
« Reply #10 on: November 12, 2014, 06:34:46 am »
The hole doesn't seat up against anything it just vents into the open space between the cases and the distributor housing.  I agree it is a pressure relief for the distributor.
Offline BLUE71TURBO
Re: RC distributor
« Reply #11 on: November 13, 2014, 10:18:59 pm »
  Here is the location of the vent hole on the R.C. Kawasaki angle drive. Way different than the Honda version.
