Author Topic: Start button relay?  (Read 2109 times)
Offline budman
  • 1914X
    • LeCompte Electric Bass
Start button relay?
« on: October 14, 2014, 06:48:15 AM »
I've recently begun a restomod on a CB750K4.  I'm getting way ahead of myself, but it's probably never too early to start thinking about this stuff.  I've been working on the wiring diagram for the bike.  I want to use some low amperage push button switches for the start button, the horn button and a kill button.  I know I'll have to use relays with the horn and kill buttons.  I'm currently using one of these switches with a relay for the horn on my v-twin and have had no issues with it.  These switches are tiny and have a very thin gauge wire.  As far as the start button goes on the CB750 I'm wondering if I should install a relay ahead of the solenoid.  I know it's redundant.  I'm just afraid I might burn up the switch.  Any down side to adding a relay ahead of the solenoid?
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline zeech
Re: Start button relay?
« Reply #1 on: October 14, 2014, 02:59:22 PM »
The switch is so momentary I don't think you're going to have an issue, I've run 16ga for a while. All you need is a grounded switch (bare metal like a handle bar) with a single wire going to your solenoid to trigger it.
Probably no downside to it. I usually error on less stuff but should probably do more. Oh well.
Offline Bodi
« Reply #2 on: October 14, 2014, 06:07:57 PM »
The solenoid coil gives a healthy inductive kickback on disconnect, I would add a diode (1N4004 or such) backwards across the switch contacts to avoid arcing and damage to a small switch.
Offline budman
  • 1914X
« Reply #3 on: October 15, 2014, 08:55:28 AM »
Good idea.
I'll probably post the diagram soon to get some feedback.
Bud
2021 Indian Scout
Offline budman
  • 1914X
« Reply #4 on: October 31, 2014, 02:46:08 PM »
Here's a preliminary wiring diagram.  It has a start button relay before the solenoid.  I found a couple of automotive diagrams with the same relay and solenoid setup.  I think the switches I plan on using come prewired with something like 20 or 22 gauge wire.  That's the reason for the relay.  I want to avoid a potential burned up switch.
Looking for feedback.
Bud
2021 Indian Scout
