Author Topic: How to tell the difference between HD and Standard cylinder studs.  (Read 1058 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
I'm about to get into a top-end job. Bike was a basket case assembled by PO.
Is there a way to know if I have HD studs or standard ones?
Use a torque wrench when loosening nuts and see when they let go?
--Evan
1975 CB750K "Rhonda"
Offline Garage_guy_chris
Re: How to tell the difference between HD and Standard cylinder studs.
« Reply #1 on: October 16, 2014, 06:57:03 PM »
OE studs are turned down (smaller diameter) in the center between threaded ends and HD studs are the same diameter the whole length
 Found this on google Top stud is OE, bottom is heavy duty
« Last Edit: October 16, 2014, 06:59:25 PM by Garage_guy_chris »
Offline Old Scrambler
« Reply #2 on: October 16, 2014, 07:07:36 PM »
BTW..........according to a few reliable motor builds in my garage..........my motor builder, Dave Murre, relates that the original studs are more reliable and have a better design.  Note the threads are 'rolled-on' versus 'cut' and the small diameter centers are designed to stretch with the motor when hot.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #3 on: October 16, 2014, 07:08:37 PM »
Skinny in the middle stock-fat in the middle aftermarket--How do you like yours ?
« Reply #4 on: October 16, 2014, 07:51:38 PM »
Skinny ones need retorqued, fat ones more likely to not need retorqued.
« Reply #5 on: October 16, 2014, 09:14:59 PM »
Fat on the top and skinny in the middle
Offline mick7504
« Reply #6 on: October 17, 2014, 04:33:59 AM »
Big Jays stud threads are rolled, thick in the middle and aint going nowhere.
If I was you
I'd be worried about me.
Offline evanphi
  • Apparently I'm an
« Reply #7 on: October 17, 2014, 05:10:12 AM »
Cool. Thanks everyone.
Also, FWIW, I like mine skinny in the middle. ;D
--Evan
Offline SOHC
« Reply #8 on: October 17, 2014, 06:46:57 PM »
Every good stud uses rolled threads, from a sohc4 all the way to a 6000hp top fuel dragster. If they dont its inferior.
Seen head stud arguments all over the internet, especially in High boost Diesels. I have heard both sides of arguments that the ford originals are better and designed to stretch, and using ARP head studs that have less stretch tend to crack cylinder heads.
Experience can vary wildly, I always look at all scenarios to see if things varied, and if that was the cause of the failure.
The use of a torque lubricant, like ARP's will give much better consistent torque readings than dry, and also takes less torque to get the same result, which also keeps the studs happier, because it puts less stress on the studs.
I used the ARP lube when i built my 347 for my mustang, and it had 15,000 hard miles on it, and I never had to retorque a bolt or stud, and probably still hasnt after i sold the car.
Current:
1979 Honda CB650 (Hardtail Build)
1983 Suzuki GS850L (Fix and Minor Restore)
Old:
1989 Suzuki Katana 600
1978 Honda CB400T "Hawk"
1983 Honda VF750
