Author Topic: How much fork oil for '84 GPZ 750?  (Read 4741 times)
Offline 750cafe
« on: October 17, 2014, 08:18:51 pm »
I will probably have much better luck here than on the Kwacker forum as they don't change their fork oil.
So, how many ounces or milliliters of oil to fill a cleaned and rebuilt fork on these?
TIA,
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
Offline calj737
  • I refuse...
Offline 750cafe
Re: How much fork oil for '84 GPZ 750?
« Reply #2 on: October 18, 2014, 09:48:23 am »
Thanks for that reply but it refers to the larger 1100 forks.
That is the site that I found a reference to the GPZ forks that said either 250 or 270ml.
I am just trying to get an accurate number for these. (they are going on one of my Suzuki projects.)
Eric
Offline calj737
  • I refuse...
« Reply #3 on: October 18, 2014, 11:07:48 am »
Yes it does, but reply #4 confirms they share the volumes. That's why I sent it.
Offline 750cafe
« Reply #4 on: October 18, 2014, 07:01:39 pm »
Hmmm. From that very forum, I have seen 250 or 270ml's posted as the correct amount.
Thanks for trying.
Perhaps I will just fill one up to the air cross over hole, measure the depth down AND pour the fluid amount into a beaker and see if it comes close to any of those figures.
The crap that came out resembled old gear oil, water and fork oil. YUCK!
Eric
Offline grcamna2
« Reply #5 on: October 18, 2014, 07:44:33 pm »
Nothing like fresh,clean forks & hydraulic fluid to keep'em working well over those hard bumps and road irregularities  :)
Offline 750cafe
« Reply #6 on: October 18, 2014, 08:42:25 pm »
A gentleman on one of the Kwacker forums replied and concurs with a 318cc fluid amount. I will just go with 320cc's and call it good.
Thanks for the help!
I am busy rebuilding the anti-dive currently on these. And the tubes are busy soaking in solvent.
Eric
« Reply #7 on: October 23, 2014, 07:50:32 am »
A general way of correct amount of oil is to measure the level. No springs or caps, fork completely collapsed, min 140mm from upper side of fork tube to oil level. This is described for progressive fork springs. I used a syringe with hose that measured 140mm from bottom. Fill forks with oil and suck with syringe. Exact 140mm guaranteed!
« Last Edit: October 23, 2014, 07:52:03 am by PeWe »
CB750 K6-76 1005cc JMR Billet block.
Offline 750cafe
« Reply #8 on: October 23, 2014, 08:12:27 pm »
They are already back together and ready to go...
I don't waste valuable riding time fixing parts.  ;)
Eric
Offline calj737
  • I refuse...
« Reply #9 on: October 24, 2014, 04:22:44 am »
Words to live by!
Offline 750cafe
« Reply #10 on: October 24, 2014, 08:20:26 am »
This is the pile as I bought a couple of weeks ago...
Hoping to have it on the road by the end of the month if I can find the good wiring harness that I have around here somewhere.
Eric
