Author Topic: 350F 1975, loose green cable on the left side cover, anyone  (Read 2202 times)
Offline samuk
« on: October 19, 2014, 07:42:52 AM »
I found this green cable loose, and its does not seem to be in the right place or suppose to be loose.
Bike does not seem to be charging the battery also.
Anyone?.
Cheers
« Last Edit: October 19, 2014, 07:46:41 AM by samuk »
Offline samuk
Re: 350F 1975, loose green cable on the left side cover, anyone
« Reply #1 on: October 19, 2014, 12:16:49 PM »
Many thanks, was not able to identify it, more pics:
« Last Edit: October 19, 2014, 01:28:59 PM by samuk »
Offline Restoration Fan
  • My wife will never call me
« Reply #2 on: October 20, 2014, 07:32:36 PM »
If you trace the wire back, can you see where the other end of the wire goes?  That might help to identify its purpose.
Offline revive_the_550
« Reply #3 on: October 21, 2014, 07:17:25 AM »
http://www.oregonmotorcycleparts.com/Diagrams/CB350_K4.jpg
Check that out?
From my experience. Green is usually ground?
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #4 on: October 21, 2014, 01:52:33 PM »
Well, I'm going to say it's purpose is a ground for a three-pin flasher unit, 750s have these too. Looks like it's got a ring connector inserted into the female spade for some reason or other. When not in use for a flasher, it's a convenient ground for something (anything) else.
Build threads:
1977 CB750 F2
1958 Norton Model 99
