Author Topic: Rear Hub Assembly  (Read 1966 times)
Offline jmelche2
  • 1974 CB750K
Rear Hub Assembly
« on: October 19, 2014, 04:50:10 PM »
1972 CB500 - While assembling the rear hub, I had a bit of difficulty installing the drive flange (the part with the studs pictured below).  I had to use a rubber mallet to install and I do not remember it coming apart with any amount of force.  Should it fit this tight?  I would like to figure this out before I move on.
Thanks, Jim
Nic
Re: Rear Hub Assembly
« Reply #1 on: October 19, 2014, 05:16:13 PM »
The best way to put it on is to fit the sprocket, put the wheel on the ground with hub facing up, align the hub, wriggle it in side to side then stand on each side of the sprocket and keep alternating your weight from left foot to right, it should go on pretty easy.
Offline jmelche2
  • 1974 CB750K
« Reply #2 on: October 19, 2014, 05:52:32 PM »
Thanks but as you can see, I already have it assembled - just a little concerned that it went together so tight.  Also, the spacer is flush with the sprocket cover.  Hmm, this does not seem right (see picture below).
Offline Jayelwin
« Reply #3 on: October 19, 2014, 05:55:37 PM »
How do you get the hub to shine like that? Just curious.
Offline jmelche2
  • 1974 CB750K
« Reply #4 on: October 19, 2014, 06:07:46 PM »
It is ceramic coating.
Offline jmelche2
  • 1974 CB750K
« Reply #5 on: October 20, 2014, 10:18:38 AM »
Bump. Somebody help a brother out
Offline Bill/BentON Racing
    • BentON Racing
« Reply #6 on: October 20, 2014, 02:21:56 PM »
It's going in rubber, so if no lube was used it will be tight, also can go in more than one way, sometimes pulling out, spin and try again, Bill. If its flush , same gap all around, you should be fine! New is also tighter fit.
BentON Racing Website
BentON Racing Facebook
Offline calj737
  • I refuse...
« Reply #7 on: October 20, 2014, 03:26:16 PM »
It is also very possible that your power coater got ceramic on the edges of the hub and sprocket carrier. Ceramic is thicker than standard powder coat (I have the exact coating on my hubs and other parts too) and it is sufficient to create friction for assembly.
Double check the edges carefully. If "contaminated" then carefully sand it down a wee bit with 320-400 grit until it's a smooth fit.
Offline jmelche2
  • 1974 CB750K
« Reply #8 on: October 20, 2014, 03:55:54 PM »
Thanks fellas!!!!!  I'm not sure who to give the prize to.  I did some sanding on the friction surfaces.  I also added some white grease to the rubber.  What made all the difference is when I added a little white grease to the leading edge of the drive flange, where it meets the hub o-ring.  On it went by hand - no hammering.  Yeah!
Offline Jayelwin
« Reply #9 on: October 21, 2014, 08:46:50 AM »
Damn, I was hoping I could get my hubs to look like that with just polish
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #10 on: October 21, 2014, 01:49:09 PM »
they will.  but you have to give them a mother's treatment once or twice a year after.  did mine on an 8" buffer....no problemo.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
« Reply #11 on: October 21, 2014, 07:51:32 PM »
I just wet the rubbers with some silicone spray.
