Author Topic: 1973 CB750 Four K3 -- Project "Terry's Fault" -- BUILD RESUMED  (Read 62651 times)
Offline edwardmorris
  • Youngish
Re: 1973 CB750 Four K3 -- Project "Terry's Fault" -- RECONDITIONING
« Reply #275 on: February 16, 2016, 07:43:31 PM »
Quick Q: Lesters don't need rim strips do they?
DH
« Reply #276 on: February 16, 2016, 08:36:33 PM »
Raf, Have you considered advertizing/doing zinc plating? If you had enough exposure and word of mouth from
satisfied customers, you could support a BIG sohc habit. Think of the possibilities. ;)
« Reply #277 on: February 16, 2016, 11:00:58 PM »
Looking good Rafi, I especially like your plating, it looks very professional! I don't know what sort of sewing machine your wife has, but if it's just your standard dressmaking machine designed to punch a small needle through soft materiel, you're gonna be disappointed.
A good upholstery machine will have a big motor and clutch/gearbox, works very slowly, and can punch a big needle and thread through several layers of thick material and pull it together tightly. I've long wanted an industrial sewing machine so I can do my own seat covers, but they're very expensive, and most used ones that have come from upholstery shops are pretty much worn out. Best of luck mate! Cheers, Terry. ;D
  • Youngish
« Reply #278 on: February 17, 2016, 12:11:42 PM »
Thanks DH and Terry! Plating is a long, boring and tedious process so I'm limiting it to only the NLA stuff. I plan on replacing everything else with stainless steel.
Regarding the seat, I did manage to renegotiate the price with MTZ based on me getting some additional work done, hopefully it will work out OK. The machine at home is meant to go only up to as thick as Denim or Corduroy so it can handle the relatively thin vinyl, but after trying out a test piece, I didn't like the finish so I didn't bother.
« Reply #279 on: February 17, 2016, 12:28:50 PM »
Way to go Rafi, I've seen so many good builds let down by sh1tty home made seats that I was worried that this build might go the same way. Good decision to stick with the pro's. I'll need to eventually zinc plate all the usual parts on my future K1 build, (picking the bike up in pieces today) did you use a Caswell kit to do your plating? Cheers, Terry. ;D
  • Youngish
« Reply #280 on: February 17, 2016, 02:01:17 PM »
Plating kit is all DIY. I keep in touch with my buddy Tom Gugliotta who wrote up the best DIY plating guide. After all the K2 bits were done, he and I had been chatting about getting the zinc to end up with a brighter finish. This build came along just in time, and I volunteered the parts I did as test dummys to his new recipe. It worked really well and was way cheaper than the kits. The only thing I used from Caswell is there final Clear/Blue passivation dip. Blue is very popular with folks here. The gold dip I DIY'd but was mostly only used on the K2 to keep the stock look. I didn't do the multi anode thingy (speeds up plating) or get a variable power supply (fine grain control). I just managed with one anode and a charger from an old router that had proper specs.
If anyone wants to try it, the DIY article is here. Tom will soon be updating it to switch out the Karo syrup with 2oz of clear vanillin (artificial vanilla flavoring available at grocery stores)
http://www.southsandia.com/website/zincplating.html
« Reply #281 on: February 17, 2016, 02:25:19 PM »
You took that seat quite a ways. It'll probably be a fairly comfortable yet supportive seat with the gel insert.  Can't wait to see photos of the finished product.
  • Youngish
« Reply #282 on: February 17, 2016, 07:21:51 PM »
Lets hope so! And here you go, what do you guys think? Personally, I think I could have done better if I had the proper tools (not bragging, just saying I'd have shown it more love).
« Reply #283 on: February 17, 2016, 08:38:54 PM »
It looks great, Rafi.  More importantly, it should provide some support and cushion for your posterior.
« Reply #284 on: February 17, 2016, 11:27:31 PM »
+1, looks good mate. Thanks for posting that plating article too, I'll check it out. Cheers, Terry. ;D
  • Youngish
« Reply #285 on: February 20, 2016, 11:09:22 AM »
The primary cush drive is back from Ralph in Germany after getting new cush rubbers installed and being re-riveted. This was made possible by our very own Wobbly/Tom, I can't thank him enough. Need to take it to the machine shop and get the new SKFs pressed in (I already had the SKFs here, distributor is right down the street but the needle rollers are always special order from SKF).
Also the new G67HP-6 HD Primary Chains made it home, hopefully these will work out better than stock, but they are slightly behind the CCC HD chains in specs.
  • Youngish
« Reply #286 on: February 20, 2016, 11:13:48 AM »
A second box with some stock rear shocks and a like new starter clutch gear made it home from Bill Benton's House of Honda Fun Land  8) You can tell from the pix that the one on the K3 has taken quite a beating. It may still be in spec but I don't like opening up engines after I'm done with them, hence the better one. The dynamo rotor is at JMR's and he noticed that the starter clutch housing that sits behind the rotor itself has taken quite a beating. Getting a newer one of that as well as the rollers, pins and springs, those are most likely shot.
  • Youngish
« Reply #287 on: February 26, 2016, 05:32:12 PM »
Roadriders and Metzelers are here, will take them to the auto shop for installation, any tips on keeping the powder safe on the Lesters? I was thinking masking tape, but would love to hear some ideas.
  • Youngish
« Reply #288 on: February 29, 2016, 09:50:03 PM »
Got the tires mounted. It was real fun trying to get the damned tube to thread through and get the tire itself on without scratching up the nice PC. Used a whole bunch of masking tape and pulled it off without a single nick  8)
  • Youngish
« Reply #289 on: February 29, 2016, 10:47:30 PM »
Also, I may be giving the rear damper rebuild a try. Acquired a used set that has some pitting on the chrome above the preload adjusters but are good everywhere else.  The damping action is shot on both, so I'm going to try and save them by drilling and tapping a hole as shown here
http://www.hondatwins.net/forums/34-tips-tricks/4049-refurbish-those-oem-shocks.html
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #290 on: March 01, 2016, 06:41:01 AM »
Those wheels look killer!
--Evan
1975 CB750K "Rhonda"
« Reply #291 on: March 01, 2016, 10:37:05 AM »
Rafi,
Nice job mounting those tires without scratching up the PC on the Lesters!   ;D 8)
  • Youngish
« Reply #292 on: March 01, 2016, 09:09:38 PM »
Thanks guys, just gotta balance them now. Where do you get those stick on balance weights? My crimp styled ones for the spokes are no good for these ;D
Long day, but I did make some time to rebuild a test dummy rear damper. Was able to drill a hole through and gunky crud, (much like what falls out the front fork lowers after years of neglect) came out. It could have been the oil burning at point of contact (drill heat) but it almost felt as if they had some sealed gas. Unlikely as the it would easily leak out from up top. Anyway, pumped the crap out of it, poured some light new oil to flush it out some more, cleaned it up and tapped it using M6x1.0, but the damned el-cheapo brand handle for the tap broke in two :o Finished up using a vice grip plier set (the tap itself was fine) and test fit a small bolt. Looks like this will work, will get the good set blasted first, then drain it, get it coated, then add new oil and seal it up with a small bolt and copper crush washer.
Offline ogsmakdade
  • bike newb
« Reply #293 on: March 02, 2016, 06:58:48 AM »
Wheels look amazing.
Everyone thinks Chuck Norris is bad, but Chuck Norris has not meet Lucky either.  Lucky will round house kick Chuck back to 1969 and pop a wheel with the 1st sandcast while shotgunning a PBR!
My "build" http://forums.sohc4.net/index.php?topic=126537.0
Offline evanphi
  • Apparently I'm an
« Reply #294 on: March 02, 2016, 07:34:04 AM »
Any auto parts store should have them, Rafi. They are also used on car wheels.
--Evan
  • Youngish
« Reply #295 on: March 02, 2016, 10:06:27 AM »
Thanks! I'll check it out later this week.
Anyone ever use this stuff before?
http://www.amazon.com/ATP-AT-205-Re-Seal-Stops-Bottle/dp/B000NVW1LM/ref=cm_cr_arp_d_product_top?ie=UTF8
Thinking about mixing this in with the rear damper oil to keep the top seal from leaking. It does list hydraulic systems as an application and is available locally.
  • Youngish
« Reply #296 on: March 05, 2016, 08:34:30 PM »
Waiting on replacement rear shocks/dampers and been very busy in general. Been plating little bits here and there but felt like putting something together today. The carb backplate got done, good call on using the blue chromate fellas ;D Sorry for the blurry pic, need to order some mains and idles then I can put the carbs back together. I had a spare set of float bowls and tops that were in much better shape than the ones I had planned on using earlier, so I got them coated paccar black 55% to have a different shade, pix soon.
Offline mashfu
« Reply #297 on: March 05, 2016, 09:13:20 PM »
That looks really nice!  I want it  ::)
  • Youngish
« Reply #298 on: March 06, 2016, 01:41:28 PM »
haha thanks! The backing plate was powder coated recently but the rest of the carb stuff was done a while back. I'm totally loving the look of the clear/blue chromate on the stealthy black powder, but I hate how easily I tend to get it dirty ::) Gonna keep a new pair of gloves handy when I do the linkage and the rest. Right now I'm dealing with cleaning out some overspray on the carb bodies, not fun :(
Offline mashfu
« Reply #299 on: March 06, 2016, 10:03:39 PM »
Definitely eager to see how it all looks after you've gotten it all buttoned up! The little things always give the biggest headaches  >:(
