Author Topic: 1973 CB750 Four K3 -- Project "Terry's Fault" -- BUILD RESUMED  (Read 70730 times)
Offline edwardmorris
  • Youngish
Re: 1973 CB750 Four K3 -- Project "Terry's Fault" -- RECONDITIONING
« Reply #325 on: April 13, 2016, 11:24:51 AM »
Original mounts, and something a LOT less than those Rizomas ;D, those are very nice but won't make the budget this time around...
  • Youngish
« Reply #327 on: April 13, 2016, 04:07:05 PM »
Thanks, those are nice too, just a bit too low for me :) Sorry I know I'm being picky, I can't believe EMGO actually has stuff close to what I'm looking for, I'll keep digging.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #328 on: April 14, 2016, 04:54:00 AM »
I figured the Rizomas were too much. ;D Most of us plebs can't afford them. They sure are pretty, though.
--Evan
1975 CB750K "Rhonda"
Offline alacrity
  • Ride, Optimize, Repeat
Re: 1973 CB750 Four K3 -- Project "Terry's Fault" -- TEAR DOWN
« Reply #329 on: April 14, 2016, 02:03:54 PM »
Just be careful, i think one member on here was selling an alloy tank, that lost a bit in fit and finish, between the online pic and actual product....not like you can easily send it back...
And check the underneath pics to see how many pieces used and how good the welds look..some are savage.. The better the guy is at forming, the less pieces used..
Yes. That member was me.
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
  • Youngish
« Reply #330 on: April 16, 2016, 10:00:16 AM »
Can upload pix again, post updated here
http://forums.sohc4.net/index.php/topic,142367.msg1795244.html#msg1795244
will get caught up sometime today.
  • Youngish
« Reply #331 on: April 19, 2016, 08:49:54 PM »
Renthal bars and ends came in a while back, need to drill them and feed the wiring through, but will hold off on that until I'm close to assembly (controls got done a year ago alongside the K2's). Finished rebuilding the seat plunger with plated and coated parts (these were done a while back, just got around to it recently).
  • Youngish
« Reply #332 on: April 19, 2016, 08:56:49 PM »
With those bars, I've got a set of NOS Euro cables to use but skipped on the Euro brake lines as I wanted to try the SS ones. Awful timing since slingshot is closed again due to tech difficulties. I tried reaching out to Shuan directly to get a set made but never heard back. Ryan/Ravi mentioned a Raymond Chan as good source for SS brake lines so I searched around and found this
http://forums.sohc4.net/index.php/topic,142604.msg1620427.html#msg1620427
Called him on his toll free line, nice guy but very particular about hose lengths, and only makes them after you specify exact sizes. Big help from Davez (runs the same bars) on the measurements, I got the order in late on Wed, lines arrived on Monday morning, pretty cool for $65 shipped. Lines look well built, I wanted all black everything including the banjos and that was not an issue, hopefully these will work out.
« Reply #333 on: April 19, 2016, 10:38:28 PM »
Pretty awesome knitting work on the back of that chair.  My mom did some similar work in the 70s.  Just right for a build thread on a 70s bike!
Offline evanphi
  • Apparently I'm an
« Reply #334 on: April 20, 2016, 05:33:49 AM »
Those bars have some bungs inside that may prevent you from running wires inside, Rafi. The walls are also much thicker than steel.
--Evan
« Reply #335 on: April 20, 2016, 06:57:06 AM »
My Mom did too!!  Ravi is multi talented!!
Thanks for the brake line info, I need to order lines for my K3 as well.
  • Youngish
« Reply #336 on: April 20, 2016, 06:58:26 AM »
@Don, thanks, the wife is big on knitting and crochet. We don't have couches because of my lower back issues, just desk chairs which get pretty cold in the winter, so she made one for each of them.
@Evan, its doable, counting on Dave again
http://forums.sohc4.net/index.php/topic,139768.msg1654873.html#msg1654873
  • Youngish
« Reply #337 on: April 20, 2016, 07:00:05 AM »
haha, Ravie sure is talented  :P :P not me though ;D
Offline evanphi
  • Apparently I'm an
--Evan
  • Youngish
« Reply #339 on: April 20, 2016, 05:50:15 PM »
Goodies returned from JMR, back cut trans, balanced dynamp rotor, shot peened, polished and balanced rods.
  • Youngish
« Reply #340 on: April 20, 2016, 05:52:20 PM »
The cam chain tensioner rollers rebuilt with the proper tool, wayyy better than what it would have looked like had I hamfisted it ;D
  • Youngish
« Reply #341 on: April 22, 2016, 06:27:26 PM »
Final box of goodies is back from JMR, check out the killer S2+ head work  8) 8)
All new everything except for collets and retainers, those are stock.
Ported, polished, milled
Honed and tapered guides
+1 intake with matching new seats cut
Full Serdi VJ
and more, all this without a nick on the powder coat anywhere  8) 8) 8) 8)
  • Youngish
« Reply #342 on: April 22, 2016, 06:28:29 PM »
More
  • Youngish
« Reply #343 on: April 22, 2016, 06:30:49 PM »
Ready to install Wisecos! HD nuts for use with Kibblewhite HD studs, and four Chrome nuts for use on the studs exposed to atmosphere 8) 8) 8)
I haven't posted pix from when box 1 was here with the cyls and all kindsa other goodies, will get caught up soon.
« Reply #344 on: April 23, 2016, 03:37:36 AM »
I use std DIN6331 collar nuts, 10.9 grade for head if I remember correctly. Kibblewhite studs. Thinner washers since the nuts collars are thick.
Thanks for the hint about the primary chains. They cost less than Honda OEM
 I have ordered 2 chains for a BMW. 530 d,  184 HP,  [E39],  Production: 1998/08 - 2000/09,  Engine code: M57 D30 (306D1)
Original partno: 11 31 2 248 729
I have the CCC chains mounted but the growing pile of parts need chains. I think I have developed a hoarder syndrome thanks to these forums :)
« Last Edit: April 23, 2016, 03:39:35 AM by PeWe »
Offline tweakin
  • tear down
« Reply #345 on: April 23, 2016, 05:29:37 AM »
I have decided to ban myself from reading your thread.  It is really giving me the itch to build another bike... :D
  • Youngish
« Reply #346 on: April 23, 2016, 09:11:45 AM »
Mireko (MessnerMoto) did all the digging on the primary chains, I just happen to be the one giving it a try  ;D ;D
  • Youngish
« Reply #347 on: April 23, 2016, 09:14:28 AM »
Chrome nuts to the atmosphere will rust (you know that right?). Why not use SS nuts?
Sure, if I do power washes and not dry after, or ride in heavy rain or things like that. Chrome will hold out better than the stock zinc or what I imagine is black oxide on the HD nuts. Original plan was to stick with stock ones, I didn't even know there were chrome ones available from Honda. This came straight from JMR. SS will be better, but I haven't worked out the specs, maybe next build...
  • Youngish
« Reply #348 on: April 23, 2016, 09:15:58 AM »
Ha! Too late Tige, there is no vaccine for the 750 bug and you KNOW you got it ;D ;D Its just a matter of time now, for that itch :P :P :P :P
Offline jerry h
« Reply #349 on: April 23, 2016, 06:43:59 PM »
Now that head looks like it means business! ;D
I'd have a hard time to stop looking at it and bolt it down.
Wow!
