Author Topic: 1973 CB750 Four K3 -- Project "Terry's Fault" -- BUILD RESUMED  (Read 64686 times)
Offline edwardmorris
  • Youngish
Re: 1973 CB750 Four K3 -- Project "Terry's Fault" -- RECONDITIONING
« Reply #350 on: April 23, 2016, 07:44:49 PM »
Now that head looks like it means business! ;D
I'd have a hard time to stop looking at it and bolt it down.
Wow!
I know the feeling! The K2 head got a pretty aggressive port job too, and I've been riding a lot lately because of the great weather we've been having here. The K2 goes pyscho starting at 3000RPMs, like REALLY pulls, which is just too much fun around town and on longer stretches.
I'm boxing up everything for cryo right now, trying to mimic the extensive packaging as they returned from Mike. If all goes well, I should have it all back within 10 days and I can start assembly. In the meanwhile, I'm finishing up the front forks, swingarm (new shock bushings) and several other little things that will eat up a lot of time. Gotta sort out a couple electrics too, using a K1 tail light and pre K2 turn signals etc. etc. busy busy busy....
« Reply #351 on: April 23, 2016, 11:31:46 PM »
Lovely port work. Mike is an artist.
  • Youngish
« Reply #352 on: April 26, 2016, 08:09:38 PM »
PSA: Allen's Fasteners now has stainless ARP flange bolts in those pesky extra long lengths used by the CB750 crankcases. When I checked few months back, no one except for baller-bolts.com had the long length ARP flange bolts in stainless. I had an order with baller-bolts that went nowhere for weeks. After some searching around, turns out the vendor is VERY hit or miss (lot more of the latter) and extremely poor communication wise. Some have had excellent luck with them, others have cursed their lungs out. Just thought I'd share, my exp was definitely bad.
ARP stuff looks pretty cool! I had a minor concern about the flange size, so I tested it out. The stock ones are obviously larger, but the ARP ones seem to cover up sufficiently well. Should I worry?
Offline MessnerMoto
« Reply #353 on: April 27, 2016, 04:41:18 AM »
SS bolts don't have same strength like stock ones. Don't use SS bolts around main crankcase bearings. For rest of crankcase bolts I am not sure. Try to dig other people experience
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #354 on: April 27, 2016, 05:08:58 AM »
You could always put a bit of thread sealer or Permatex Ultra Black Form-A-Gasket No. 2 (non-hardening) around the head?
« Last Edit: April 27, 2016, 11:30:25 AM by evanphi »
--Evan
1975 CB750K "Rhonda"
  • Youngish
« Reply #355 on: April 27, 2016, 11:10:42 AM »
Main bearings are getting APE HD studs and nuts, this thread is missing an important update from when I wasn't able to upload pix, I will add those tonight for sure. Rest of the crankcase bolts are all 6mm and need a measly 96in-lb torque, I was assured ARP SS h/w is plenty strong :)
  • Youngish
« Reply #356 on: April 27, 2016, 11:12:01 AM »
You could always put a bit of thread sealer or Permatex Ultra Black around the head?
I might just do that (very lightly) on the few bolts on the lower crankcase may be near oil, not too worried about the upper ones. The flange does cover the hole completely, just not above and beyond like the stock ones....
Offline evanphi
  • Apparently I'm an
« Reply #357 on: April 27, 2016, 11:30:02 AM »
Forget the Ultra Black - use the Form-A-Gasket No. 2 (non-hardening)! My bad. Same stuff used for the cam tower pucks. I would figure it would be better than thread sealant because there's no threads near the flanged head?
--Evan
  • Youngish
« Reply #358 on: April 27, 2016, 01:09:20 PM »
Pretty much knew what you meant ;)
Offline timbo750
« Reply #359 on: April 27, 2016, 04:49:35 PM »
Trying to decide on electrics, was looking around on Rick's stuff and it seems they have a starter solenoid too? Any feedback on that? I'm thinking about
Rick's RR
Rick's Starter Sol
Hondaman fuse unit
Hondaman safety unit bypass plug
Stock winker relay
Ed, did you end up getting a HM safety unit bypass plug? i have been looking for one but HM doesn't have one listed on his web site, i ma happy to wire one up myself if I can get a schematics.
  • Youngish
« Reply #360 on: April 27, 2016, 08:46:43 PM »
Yes, I don't have it here yet, but I did ask for it along with a few other things I'm getting from Mark. Its a pretty simple bypass, pretty sure its in the FAQ or in older posts somewhere here.
  • Youngish
« Reply #361 on: April 27, 2016, 08:47:57 PM »
Missed update from a while back...........
Box 1 arrived from JMR with the cylinders all done and these goodies. Megacycle hardweld rockers, HD timing chain, APE adjustable sprocket, yami FJ sprocket bolts, APE bearing studs, Kibblewhite cyl studs, Barnett springs, MLS head gasket, viton coated metal base gasket.
Offline evanphi
  • Apparently I'm an
« Reply #362 on: April 28, 2016, 05:49:40 AM »
Mostly for others reading. ;D Big difference between the two!
--Evan
Offline MessnerMoto
« Reply #363 on: April 28, 2016, 06:17:11 AM »
I see that they are using some other stainless alloy. I was thinking that they are from A2/4 stainless...
  • Youngish
« Reply #364 on: April 30, 2016, 08:30:05 PM »
Front brakes on the car were almost shot, so that took up most of today >:( >:( Finally got those pesky 6x10 screws for the fork drains, finished assembly on the front forks with new progressive springs. Balanced the wheels, was going to assemble them and hit a blocker with the rear wheel axle getting chromed too thick (K2 deja vu), gotta take that back and thinned out next week. Was going to do the front wheel and realized I need to work on the speedometer drive first, oh well, there's still part of tomorrow left to get what I can done. Sure as hell can't go riding because of this incessant rain >:( >:(
  • Youngish
« Reply #365 on: May 02, 2016, 06:21:29 PM »
Stuff back from Cryo, glad to see it come back packed as good as I sent it, even better actually. But so friggin tired of packing and unpacking stuff, time to begin assembly! Gotta clean it all up one more time, not sure what the somewhat sticky lube is on the parts...
  • Youngish
« Reply #366 on: May 07, 2016, 09:25:45 PM »
Progress has stalled for a bit due to a blocker, and lately good weather + free time has been translating to riding the K2 at every opportunity. A while back I was looking for alternatives to stock handlebar levers as I did not want to polish up the rather rough ones that were on the bike. I ended up finding a set of chromed "dog leg" styled aftermarket ones. On of my stops at the local bike shop, we were chatting and the owner (who LOVES the K2) said to me "You've got too large hands for them bent things". I told him others have said that too, but I really don't want to keep up with the polishing (the K2 is enough work :P), so he asked me to drop off my old ones next time I came by. I did, then forgot about it for a long time. Went by there today, and loooky! All smoothed out and chromed up! I don't even know what these are going to cost me but damn they look cool 8)
  • Youngish
« Reply #367 on: May 09, 2016, 05:56:13 PM »
So, I'm a little worried about something now. This K3 originally came with a set of CB450 gauges which wasn't going to work, so I bought a set of 73 750 gauges on ebay last year. The 450 gauges felt like they were sort of force installed on the top triple and I didn't want to worry about its structural integrity. So I asked the same ebay seller if he had the triple that went with the gauges. He said he had it, so I bought them together.  Guages got rebuilt using goodies from Marcel, and I forgot all about the triple. I didn't realize that I already had another spare 73 top triple laying around, so I just got that powder coated and threw the ebay one in my spares pile. Now this I call pure luck, because I was reading this thread today
http://forums.sohc4.net/index.php/topic,157454.msg1804674.html#msg1804674
and went back and checked to make sure my triple was correct. Thankfully the spare I got powder coated is the correct one, but the ebay spare that came with the gauges is from a friggin 550! My worry now is that I may have rebuilt 500/550 gauges and I'm not sure if they'll work as a drop in on the 750? When I worked on them, they looked like they were 750 gauges. I'll have to go through my old boxes and see if I still have the old gauge faces to confirm the red line. IIRC, the ebay listing had tons of pix of the gauges and I'm fairly certain they are correct, but just in case they aren't, what can be done besides finding another set?
« Reply #368 on: May 09, 2016, 06:34:21 PM »
speedo will work fine...550 tacho will read incorrect as the drive gear on the camshaft has a different amount of teeth
  • Youngish
« Reply #369 on: May 09, 2016, 07:09:02 PM »
DAMMIT! Looks like they were 550 and I completely missed it >:( >:( >:(
@Sean, are the innards on the tach different or just the gear under the valve cover? Would hate to redo those so close to assembly time :-\
« Reply #370 on: May 09, 2016, 07:39:01 PM »
Unfortunately, I think the tach innards are identical...it's the gear on the cam itself that is different.  I guess you could run a 550 cam and...oh wait, nevermind. :'(
That sucks.  I have made similar mistakes, just without the rebuild.  Currently having tach problems myself as I just literally wound the needle off the one on my gold bike.
  • Youngish
« Reply #371 on: May 10, 2016, 10:07:56 AM »
Cam gear is different. Clocks are different innards too. Find a new set.
Will swapping the tach gear at the cam with one from a 550 not work? I'm getting conflicting reports, some have used 500/550 tachs on 750s as is and claim they work, some say just the tach gear needs to be changed, others say there is no way to get it work at all... :-\
« Last Edit: May 10, 2016, 10:11:34 AM by edwardmorris »
« Reply #372 on: May 10, 2016, 02:04:53 PM »
As is?...it will work but will read 500 or 600 rpm too high.  Swap the gear in the valve cover?...I dunno?  I know that the gear on the cam cannot be swapped.
  • Youngish
« Reply #373 on: May 10, 2016, 02:56:18 PM »
OK, more digging and it turns out the face markings for the RPMs are different, so using a 750 face (which I did) should correct that, provided nothing else changes (not even the gear under the valve train cover) right??
« Reply #374 on: May 10, 2016, 03:19:53 PM »
I really dont know.  I was under the impression that the only real difference in the faces was the redline rpm.  I would compare as many part numbers as possible between 550's and 750's.  All I can really tell you for sure is if you slap a stock 550 tach on a stock 750, it will report an obviously too high rpm.  This I have done.
