Author Topic: $4.95 Float needle assy vs $15 Float needle assy??? cb550/cb500  (Read 1011 times)
Offline L.A. Nomad........
  • 1976 CB550 K
4into1.com Offers a $4.95 float needle assy(Taiwan made) for a early CB550/500 carbs.. Anyone try these parts out??  They also sale the Keyster(japan made) float assy for $15 a set. Keyster have great for me in the past.
I'm very curious!!!!! I guess curiosity killed the cat too. HA!
Taiwan made $4.95
http://4into1.com/replica-keihin-float-needle-valve-assembly-16011-329-004/
Keyster Japan made $15:
http://4into1.com/keyster-float-needle-valve-assembly-for-keihin-carbs-cb350-cb400-cb500-cb550/
I am a fuel-injected suicide machine! I am a rocker! I am a roller! [I’m an outta controller] I am the Chosen One! The Mighty and the Vengeance! Sent down  to strike the unroadworthy! I'm hotter  than a rolling dice!
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: $4.95 Float needle assy vs $15 Float needle assy??? cb550/cb500
« Reply #1 on: October 24, 2014, 02:00:42 PM »
http://www.jetsrus.com/individual_parts/KL_18_4762.html
More expensive but far less headaches in the long run.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline harisuluv
« Reply #2 on: October 24, 2014, 02:07:52 PM »
I suspect that the jetsrus float valve assy is also keyster.  You will also find that when one place is out of these, almost everywhere is out of stock of them.  They are probably all from one supplier.
Also, that jetsrus assy has no brand associated with it.  When people do that, they want to hide the brand.  Do not mistake keihin "compatible" or for "keihin type" with actual KEIHIN products.
The cheapo assy in the original post I recognize from the shape of the valve, it is the same "made in Japan" part included in the kits sold by "cruzinimage."  They are garbage and I can tell you firsthand.  Some of the springs would actually get stuck in the depressed position right out of the bag.  Don't waste your money on them.
For what it's worth, the keyster valves in my experience work fine and will seal good.  However, on some models like the 350F or 400F the floats aren't made for the slightly longer plunger, so in order to get it similar to OEM you need to tweak the float a bit.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #3 on: October 24, 2014, 02:13:25 PM »
Interesting. Jets-r-us was the one place I found OEM keihin pilot jets for the 76 550F and was happy to have found them. The PO had put after market in two of the carbs and it would never idle or come off idle very well until i replaced them all. Purred like a kitten after that.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
  • 1976 CB550 K
« Reply #4 on: October 24, 2014, 02:48:33 PM »
Thanks guys! I thought the $4.95 assemble was too low.
Offline harisuluv
« Reply #5 on: October 24, 2014, 02:53:23 PM »
Well that is quite possible, what I said was related to the assy and links provided.  A pilot jet is a totally different part.
