Author Topic: Fork tube fitment  (Read 533 times)
Offline Djfob
Fork tube fitment
« on: October 25, 2014, 07:24:13 AM »
Are the tubes the same from 69-78? Need a replacement for my k8. I know the lower legs differ between years.
78 CB750k
Re: Fork tube fitment
« Reply #1 on: October 25, 2014, 08:00:13 AM »
No the 69-72 are a different style than the 73- up, I think the lower leg got longer in 76.
« Reply #2 on: October 25, 2014, 09:09:15 AM »
The 77/78 tubes work in 73 and up..best tube to run as it is plated top to bottom . The 77/789lowers are longer and easier to get fork braces for.
Offline avoca
« Reply #3 on: October 26, 2014, 11:39:54 AM »
You coud just use the triple trees from the same year that youre getting the tubes from.  The only thing that will make  a difference/issue would be the bearings possibly.  FOr instance, I put an 81 front end on my 73; the 81 had fixed bearings awhile my 73 had ball bearings.  Used ball bearings for the top of my triple tree and fixed on the bottom.  Worked well
Offline BPellerine
« Reply #4 on: October 26, 2014, 03:48:01 PM »
if you get tubes from an earlier bike get them both as there was a little diff in length ,bill
1978 CB 750K ard and webers
another anfob
