Author Topic: CB750F Jetting Question  (Read 1030 times)
Offline rockandride6
« on: October 27, 2014, 08:37:17 AM »
Well, at least I THINK it is a jetting question.  I just finished rebuilding my 1975 CB750F to what I would call "restored+" with the goal of modifying it as someone might have done when it was new.  The only real engine change I made was pod air filters and I believe I have tracked my issue down to that.  With a 110 main (just rebuilt the carbs, so everything else is stock with the exception of being one position UP on the needle) I can't really open the throttle up past 1/8th without it bogging down
I thought it was too rich, so I switched back to the stock 105 main and it got worse.  Now, I understand (or think I do) it is running far too lean and STARVING for fuel.  I can run it pretty well with the choke on a bit, but if I open up the choke and try to ride, no go.  I have a set of 120 Main Jets, should I give that a shot? If I am running 120 mains, should I change anything else? (pilot jet?)
I really don't want to have to dive into it, but should I change the needle clip position?  Thank you all so much for any help!  Here she is in all her glory:
1975 CB750F (Restored with some "period" modifications)
1975 CB750F (Waiting in the wings for a full custom cafe-build)
1974 CB750K (Project Donkey D*ck. Build in Progress: http://forums.sohc4.net/index.php/topic,151314.0.html)
1976 CB200T (Original)
1977 XR75
2006 CRF450X
2003 CRF150F
1979 Vespa P200E
Re: CB750F Jetting Question
« Reply #1 on: October 27, 2014, 08:45:44 AM »
pods make it lean.  you'll need to INCREASE fuel supply across the throttle range.
add your 120's, and be prepaired to change your mixture screw setting, increase pilot jet size, and (probably) make a needle clip change.
Only accurate plug chop tests can show you what is necessary.  Make only one change at a time and test.
« Last Edit: October 27, 2014, 08:50:25 AM by flybox1 »
« Reply #2 on: October 27, 2014, 08:51:43 AM »
I now see you still have the stock exhaust on the bike, hopefully you still do.
Change back to, or get a stock airbox to go with it.  Your bike will thank you.  ;D
Offline RSchaefer
« Reply #3 on: October 27, 2014, 11:06:16 AM »
Love the color!!!!!
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline Cqyqte
« Reply #4 on: October 27, 2014, 12:42:14 PM »
I have a '75 CB750F with 849cc pistons and I put a set of '77 carbs on because of the accelerator pump features.  My '77s run 125 mains 35 pilots with 1.75 turns out and K&N pods and I have yet had an issue with fuel mixture ratio.  I know the big bore pistons will demand more fuel flow but I would try the 120 mains or the 125 mains to get a read as to how rich or over rich they may make things.
Offline Cqyqte
« Reply #5 on: October 27, 2014, 12:44:51 PM »
The accelerator pumps make a big difference in tuning the off idle transition with the pods.  So if you can can your hands on a set cheap jump at them. ;)
« Reply #6 on: October 27, 2014, 12:57:45 PM »
Thanks for all the input and comments everyone!
I will try the new mains later this week and report back with the rest as well!
1977 XR75
2006 CRF450X
2003 CRF150F
1979 Vespa P200E
Offline Guido56
« Reply #7 on: October 27, 2014, 01:03:55 PM »
I had the same problem with my K1
I solved with jets 130.
All are advised not to change the idle jet and the position of the needle.
Honda four 750 K1
Kawasaki Z1300 A3
Benelli TNT1130
« Reply #8 on: October 27, 2014, 01:19:47 PM »
why?
Offline Guido56
« Reply #9 on: October 27, 2014, 01:38:20 PM »
'Cause it's too hard to work on carburetors and get a good result.
There are too many variables.
If the carburetor and 'lean, better to increase the main jets without changing too much.
If I'm not mistaken, all carburetors Four of the jets have the minimum of 40.
The height of the needle, changing the fuel mixture at medium revs.
Sorry, I'm using the translator.
Honda four 750 K1
Kawasaki Z1300 A3
Benelli TNT1130
« Reply #10 on: October 27, 2014, 02:41:09 PM »
actually, these carberators are quite simple to work on.
you have a few areas to make adjustments based on throttle position, and plug insulator deposit results from plug chops/dyno tuning
If you have a good stretch of road to load your bike, and safely do a plug chop, the process is simple.
Pods change A/F mixture throughout the throttle range. The OP still has to match main jet, slide needle height, pilot jet and mixture screw settings to the the pods on the bike.
Just increasing mains wont be enough..
Offline Guido56
« Reply #11 on: October 28, 2014, 12:37:08 PM »
I did not say that It is impossible, only that 'complicated by failing to provide all the things you listed.
Definitely not 'thing to everyone ;)
Honda four 750 K1
Kawasaki Z1300 A3
Benelli TNT1130
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #12 on: October 28, 2014, 01:52:11 PM »
Rockandride, Flybox is giving you good advice. One step change, plug chop, and if all good move on to next step. I think you're going to end up with 125/130 mains, that's my experience anyway. Try the needle clip one position lower than stock - raising the needle. I run PDs, never found it necessary to increase the size of the pilots, although I'll readily concede that doing so would improve things further. It's acceptable to me, and that's the key with pods, reach a state of tune that you are happy with but don't expect it to run as well as the stock set-up. With time and patience though, you can get pretty close and it'll be a blast to ride, as long as it's not too windy and you've got deep pockets!
Build threads:
1977 CB750 F2
1958 Norton Model 99
