Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
all the other seals like kicker/shifter/output shaft etc are only splashed from behind with oil,the main crankshaft ones are holding back up to say 60 + psi of hot pressurised oil,id be using the lipped ones incase they blow out.
$19 when you guys say 518 loctite, do you really mean permatex?
