Author Topic: 400F clutch adjuster ?? Found one thanks.  (Read 1024 times)
« on: October 28, 2014, 07:37:46 AM »
 My 76 400F is missing the clutch adjuster that threads into the engine, they are discontinued and the po lost mine. I'm thinking a step drilled bolt would work fine, 10 x 44 mm. Not having one to look at, does this sound like a viable option?
  link didn't work.
« Last Edit: October 28, 2014, 08:41:10 AM by Don R »
Offline vames
Re: 400F clutch adjuster ??
« Reply #1 on: October 28, 2014, 08:12:40 AM »
Yeah that thing is a bugger to find. Seems like you could make one yourself as noted. But before you do -- call David Silver Spares and ask them. It's not listed on their site, but they are up to their necks in 400f stuff after restoring all those bikes in the past few years. I bet you if you ask nicely they can source you one. That's what I would do.
« Reply #2 on: October 28, 2014, 08:36:29 AM »
Thanks Vames. I have a big order en route from there now. A few parts were on the us site but located in England.  It appears they were used on the 200 maybe more.
 I considered drilling the case and using a 750 cable but the one I have is too long.
« Reply #3 on: October 28, 2014, 08:40:50 AM »
 Well, I typed the part number into ebay and got one for $14 shipped. Should have it friday. Maybe I'll make a few when I get it.
Offline bjbuchanan
« Reply #4 on: October 28, 2014, 01:53:55 PM »
My 4into1.com cable came with an adjuster for the case...
Offline rockvegas400
Re: 400F clutch adjuster ?? Found one thanks.
« Reply #5 on: October 28, 2014, 03:22:10 PM »
I located a new one at Phil Denton engineering a couple of years back. They make quite a few parts for Hondas.
http://www.phildentonengineering.com/
1975 CB400F
1988 VFR750F-J
« Reply #6 on: October 28, 2014, 06:18:58 PM »
 Thanks, both posts have good to know info. I lost my 4 into1 link good to have it back.
