Author Topic: Flywheel bolt  (Read 1274 times)
Offline Bokeh
Flywheel bolt
« on: October 28, 2014, 09:24:52 PM »
Any advice on removing the flywheel bolt.  Cant seem to get that bugger off.  Got it sitting overnight with penetrating fluid sprayed on, but dang gave it a helluvah pull with a screwdriver stuck through the openings to hold it from spinning.  Lifted the bike off the ground and the bolt didn't move at all nor make any snap or pop sounds like it was about to.  Didn't want to heat it up.  figured someone may have a trick.  This engine is getting fully rebuilt so it's gotta come out.  I was also interested in Anders alternator upgrade as well.  Would love to have the extra juice.
Offline jonnycakes
Re: Flywheel bolt
« Reply #1 on: November 02, 2014, 12:43:44 PM »
Impact driver maybe....the last one I did brought the treads with it so..........
'Matic-Fanatic
Offline Bokeh
Re: Flywheel bolt
« Reply #2 on: January 02, 2015, 09:40:48 AM »
Well I tried putting a torch to it and still wouldn't budge.  However,  I tried a trick I found on You Tube and thought I would pass it along.  I took the spark plug outta #1 cylinder (doesn't matter which you use).  Stuck my finger in and felt when the cylinder reached the top.  Then spun the flywheel to bring the piston back down.  Then I fed some soft nylon rope i had lying around into the cylinder through that hole (took about 10 feet although I'm sure it would work with less).  Spun the flywheel again and the rope stopped the piston.  Put the wrench on the flywheel bolt (the handle about 45 degrees basically aiming to the headlight,  grabbed the handlebars,  and put one foot on the wrench handle.  Viola!  I was kinda hesitant to try this but it worked like a charm.
