Author Topic: How do I remove seized Barrels  (Read 4371 times)
Offline Keith61
« on: October 29, 2014, 12:37:50 PM »
Hello . New here so hope this is in the right place.
I have an old CB550 which I have great plans for , first of which is to strip and clean the engine.
The problem I am having is that I cannot get the barrels off the casing. When removing the nuts from the engine studs all came off except for the stud at the front between cylinders 2 and 3 which sheared easily as it was heavily corroded. I have managed to get movement around the base apart from an inch or so either side of this stud which won,t budge. I have tried hitting with a mallet to loosen . When it was in the bike I fed a rope through the stud hole and used a lever over the frame to pull up. No joy. Now it is on the bench I have fed a nut through the fins threaded a bolt trough it down the stud hole and on to the end of the remaining stud  and used this to try and lift the barrels again no joy . All with regular soakings of WD40 and beatings with the mallet. If anyone has had a similar problem any help would be greatly appreciated as I am now out of (limited) ideas .
Thanks .....Keith
Offline Davidov
  • 1978 CB750 F3
    • My CB750F project log
Re: How do I remove seized Barrels
« Reply #1 on: October 29, 2014, 12:46:32 PM »
The pistons are seized in the cylinders?
Or do you mean that the cylinder assembly won't come off of the crank case?
http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=360001
-David
« Reply #2 on: October 29, 2014, 01:08:05 PM »
be careful not to break fins
remove all studs
one trick is to fill cylinders with 50/50 atf/acetone mixture and let it set for a few days, refilling as needed.
this will get the atf in past the rings and loosen it up.
Offline calj737
  • I refuse...
« Reply #3 on: October 29, 2014, 01:08:57 PM »
Try rotating the crank using the bolt under the stator, NOT under the points cover. Agree, your pistons sounds as though they're hanging up the cylinders. Plenty of penetrating oil in the cylinders, rotate the crank, and continue to pry the jugs up.
If not, the other proven method is to bolt the head to the jugs, stuff cotton rope in the chambers, then rotate the crank. The rising piston will push the cylinders up with head attached to it.
Offline Keith61
« Reply #4 on: October 29, 2014, 03:17:17 PM »
OK Thanks. Pistons are free in the bores , the barrels are just stuck to the top casing around the broken stud. Using the pry slots either side I can see slight movement it is just solid round this stud. Have a slight problem with the rope in cylinder idea in that the 6mm bolt on the front of the barrel has also sheared so I will have to get that out first
Offline Rocky2010
  • Live in Strayla
« Reply #5 on: October 29, 2014, 04:05:02 PM »
Interesting read referring to the fire in the hole for a seized piston in the bore  :)
2010 Harley Fatboy Lo
1972 Honda CB750/4 Under Restoration
1971 Honda CB500/4 Original Condition
1972 Honda CB350/4 Original Condition
1972 Honda XL250 Motorsport Under Restoration
1967 Honda C90 Original Condition
1968 Honda S90
1962 Triumph Speed Twin
1952 Triumph Speed Twin
1970 Bultaco Sherpa T
1971 Bultaco Alpina
1958 Moto Guzzi Zigolo
1970 Moto Guzzi Ambassador Original Cond
1973 Yamaha RD250
1948 Velocette x 2
1942 WLA Harley Davidson
2006 Kawasaki ZX12R (Sold)
1980 Corvette
Offline rb550four
« Reply #6 on: October 29, 2014, 07:33:32 PM »
Keith, I have  stupid questions, is the entire head is off right? I mean , you have an unobstructed view of all the pistons in the cylinders, right??
  If it is only that the barrels are stuck to the upper case why not some slide rachet straps (or wire) through the barrels and hang it from the rafters or the work bench so that the front of the motor is an inch off the floor and the lower rear mount is up on a 2x4 and let gravity and the weight of the tranny do the work... it's like a constant pull upwards on the jugs . Leave it hang for the night and see if that works for you.You can add more weight on the tranny, near the jugs if it isn't enough weight.
I've hung a few  stuck motors off the rafters out of the bike before but, had quicker results while it was done in frame and was able to use the weight of the rest of the bike to do the work. Low impact and you can do this in your sleep.
Offline Davidov
  • 1978 CB750 F3
« Reply #7 on: October 30, 2014, 06:36:59 AM »
http://www.youtube.com/watch?v=MO1jjOSkpms&list=UUOm_dzAtaif27WLbbUOYCzQ
Seized pistons  ;D
If your cylinder head is off, the cylinder assembly should lift off of the studs. The studs won't be holding it after that.
-David
Offline rb550four
« Reply #8 on: October 30, 2014, 06:48:13 PM »
 That's what I thought until I re read Keith saying the pistons were free in the cylinders.
 I have had a couple motors go through here where the studs were so corroded and crusty that they wouldn't break free easily , and it took some real work to slide the barrels up the rods. I suspect he could have run into a motor with the same problem.
  It'll be interesting to see what the problem really was.
« Reply #9 on: October 30, 2014, 08:31:13 PM »
 electric heat gun?
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #10 on: October 31, 2014, 09:55:34 AM »
Sure you got all the bolts? You could try tapping it with a rubber mallet but not too hard you might break the fins. They should come right off though. In fact the biggest problem with doing just the head is when you lift the head the jugs usually break the seal at the case unless you get really lucky like me  ;)
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=8qs9c2kooarh8oquhotqqgav95&/topic,60973.0.html
« Reply #11 on: October 31, 2014, 10:05:32 AM »
its happens the cylinders get stuck,,if the bike are in vet clima..my 400 four vas cylenders rusted together vith the pin bolts.and i vas not abel to lift the it off..have to made some vood brikks to put under the cilender block..and then hammer carefull to it got loose and heat it some..use avooden block to use the hammer on..
i hate all this v-w.... vords
Offline setdog
« Reply #12 on: October 31, 2014, 10:27:46 AM »
Could dowel pins be rusted and causing cylinder to stick to case?
Penetrating lube and wait it out?
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
Offline calj737
  • I refuse...
« Reply #13 on: October 31, 2014, 11:28:42 AM »
Definitely flood the stud holes with penetrating oil, then apply heat at base where the dowels are located. A propane torch will not hurt the cases at all. Even might help separate the gasket in case someone previously used gasket glue  :-[
Offline Keith61
« Reply #14 on: October 31, 2014, 12:46:50 PM »
Thanks for all the responses . All bolts are out and everything is off that should be so I suspect it is corrosion holding this together. The bike is a do,er up off ebay and came with the engine caked in mud so I suspect it was put away dirty and stayed that way. For a long time !! Haven,t tried heat yet as I was worried it may warp the block if not heated evenly . I only have a small blow torch but will give it a go. I have heard that there are dowels around each stud . Is this correct ? .
Busy for a few days but will let you know how I get on
« Reply #15 on: October 31, 2014, 12:56:39 PM »
remove the bottom case, flip her over, and pull out the crank/rods/pistons
