Author Topic: Cb500/550 Float question. What makes'm Buoyant??  (Read 600 times)
Offline L.A. Nomad........
  • 1976 CB550 K
« on: October 30, 2014, 03:46:32 PM »
The Cb500/550 carburetor floats: Do they hold pockets of air on each side??  Or is the material on each side buoyant?
I have one with some wear and a pitted surface.
I am a fuel-injected suicide machine! I am a rocker! I am a roller! [I’m an outta controller] I am the Chosen One! The Mighty and the Vengeance! Sent down  to strike the unroadworthy! I'm hotter  than a rolling dice!
Offline rb550four
Re: Cb500/550 Float question. What makes'm Buoyant??
« Reply #1 on: October 30, 2014, 05:57:42 PM »
Air.
« Reply #2 on: October 31, 2014, 08:40:45 AM »
the black foam float material is less dense than the density of fuel.  they are solid.
the brass floats use air to keep them afloat.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #3 on: October 31, 2014, 09:39:50 AM »
550s have foam floats so, solid/ more bouyant than gas
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
  • 1976 CB550 K
« Reply #4 on: October 31, 2014, 10:36:54 AM »
Thanks guys!!
I'm going through my bin of really rough carb parts/racks. Refurbishing what can be salvaged, then setting them free...
I've rescued most everything, even a carb rack that sat in a parts cleaner tank for months!
Tools that helped: Blasting cabinet: Baking Soda, Glass beads, tiny bristle brushes, steel wool, brass brushes, chem dip (yuk!)..
Only 2 things I couldn't rescue, 2 carb bodies.
carb 1-Post for float pin is broken, I have the broken part. (i have hope for repair)
carb 2- The post where the main jet sits, has been eaten away by corrosion! The rest of the body is perfect!  Any ideas for this kind of repair???
« Reply #5 on: November 01, 2014, 12:25:46 AM »
they only float as they weigh less than the fluid they displace,same as anything.
Offline RevDoc
« Reply #6 on: November 01, 2014, 09:30:55 AM »
"carb 1-Post for float pin is broken, I have the broken part. (i have hope for repair)"
Nomad, I have a friend who is a retired bike racer and now has a small repair shop that I help out in occassionally.  He has had success with this type of repair using J-B Weld. Found in most adhesive aisles of auto parts or DIY stores. Trick is making sure the carb can sit undisturbed in a warm dry place for 24 hrs. for full strength.  Float pin in column, of course, to ensure proper alignment.
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
