Author Topic: Re: Bigsam302's 76 CB750F (915cc): Project Helen – Running Report!  (Read 64787 times)
Re: Bigsam302's 76 CB750F w/GSXR Forks: Project Helen - Finally, progress!!!
« Reply #75 on: August 25, 2015, 10:51:02 PM »
Sam,
How much did RG3 charge to anodize your BPF forks?
Offline Bigsam302
    • 1976 CB750F (915cc) Super Sport
« Reply #76 on: August 26, 2015, 05:52:43 AM »
Sam,
I think that they charged me about $220.00 for the anodizing.  It ended up costing a lot more than that because of the revalve and rebuild.  They offer other colors as well.  On their website they give you the option of a polished coating, but it is not available.
Sam
1976 CB750F (915cc) Super Sport: http://forums.sohc4.net/index.php?topic=142578.0
« Reply #77 on: August 26, 2015, 07:52:33 AM »
I'll have to think about that once my bike is fully mocked and weighed.
Offline Bigsam302
« Reply #78 on: August 26, 2015, 08:56:17 AM »
Yeah I hear you!  I think that once you start putting "Hot Mess" together, you will want to go in that direction.  I was looking for all kind of options, including stripping off the coating and polishing them.  This turned out to be the better option.
« Reply #79 on: August 26, 2015, 10:25:16 AM »
I am exploring anodizing since there is nothing good on the bike and the finish could use a refresh. It all depends. I am already planning to revalve if there is a significant weight variance.
Offline Bigsam302
« Reply #80 on: August 27, 2015, 07:28:30 PM »
Yesterday I dropped my tank and seat off at a local motorcycle paint shop.  Here is the color scheme that I am going with.  It’s off of a 2014 Toyota FJ Cruiser.  The color is called Heritage Blue.  It is going to also have two black racing stripes and a custom Honda logo on it.  The shop owner said that he should have it finished in 2 to 3 weeks.  The rest of my bike should be ready to go by then.
Offline Bigsam302
« Reply #81 on: August 27, 2015, 07:29:26 PM »
Got a little work done today.
Pulled out my new Cycle X Super Studs made by Kibblewhite and installed them.  These are way better than OEM!
Offline Bigsam302
« Reply #82 on: August 27, 2015, 07:31:44 PM »
I cleaned, taped off, and painted the cylinder block and head.  I should be able to be able to bake them in the oven tomorrow after the wife leaves the house.
I can’t wait to run this cylinder head.  It has:
-Cycle X #4 Race Port
-Kibblewhite 5mm Bee-Hive Spring Conversion Kit
-Oversized intake valves
-Light weight intake valves
-Light weight exhaust valves
-Intake guides and seals
-Exhaust guides and seals
- Keepers and lash caps
-Titanium retainers
-Chrome silicon springs
= BEAUTIFUL!
You can’t see it in the picture, but it is cool that Ken at Cycle X engraved my name in the bottom of the cylinder head.
That's all for tonight.  More to follow!
« Reply #83 on: August 27, 2015, 07:41:13 PM »
Awesome, Sam.  Don't let the wife sniff out the paint in the oven!!
Offline Bigsam302
« Reply #84 on: August 27, 2015, 07:45:27 PM »
Yeah, I'm going to get home extra early tomorrow  ;D
Offline Bigsam302
« Reply #85 on: August 27, 2015, 07:46:45 PM »
And what cam are you planning, Sam?
Cal,
I got Cycle X's CX-7.  It's the one that works best with the 915cc kit and what Ken and MReick recommended.
« Reply #86 on: August 27, 2015, 10:53:47 PM »
Mike recommends the CX-7 camshaft for the 750 higher compression big bore (836-915) kits.
That port job should really wake up the motor, Sam.
I have some of the same spec goodies going into my 750 motor.  I cannot wait to see what a little beastie she becomes.
Cycle X HD primary chains and tensioner
Cycle X race transmission
Slightly Lightened and Balanced crankshaft
Balance rotor
Cycle X Super Rods
Wiseco 836cc big bore kit
Cycle X Super Gasket set
Mike Rieck Stage IV port job, Kibblewhite 5mm valve conversion kit (34mm intake/28mm exhaust valves, guides, seals, springs, Ti retainers,
spring bases and lash caps), Serdi valve job, head milling
HD Cam Chain
APE adjustable cam sproket
APE HD studs
Cycle X CX-7 cam
Cycle X racing cam tensioner
Cycle X Cam Tower Stabilized Valve Cover
Cycle X Spin-Off Oil Filter Mount
Setrab Oil Cooler
Offline Schenk
« Reply #87 on: August 27, 2015, 11:06:05 PM »
Wow, nice build man!
Offline Bigsam302
« Reply #88 on: August 28, 2015, 06:32:52 AM »
Balance rotor
Cycle X Super Rods
HD Cam Chain
APE HD studs
Cycle X CX-7 cam
Setrab Oil Cooler
We are on the same page!  I have all that stuff as well.
« Reply #89 on: August 28, 2015, 07:24:27 AM »
Balance rotor
Cycle X Super Rods
HD Cam Chain
APE HD studs
Cycle X CX-7 cam
Setrab Oil Cooler
Sam,
I thought so, too. The motor is very similar in spec to Doctor D's 750SS. Twinline was able to get 80s rwhp.
Offline Bigsam302
« Reply #90 on: August 28, 2015, 08:21:56 AM »
Sam,
[/quote]
Yeah, I based my motor off of Tweakin and DoctorD's builds.  My only regret is that I have never rode a stock CB750 before.  It would be nice to have something to compare my build too.
« Reply #91 on: August 28, 2015, 08:34:23 AM »
Well, in comparison to the bike you are building, the front end is spindly, the brakes are MUCH less powerful, the front handles a fraction as well, and the motor is anemic compared to one with a big bore, port and cam.  It will be like night and day.
Offline CBertels
« Reply #92 on: August 28, 2015, 09:09:52 AM »
This build looks amazing, great job!
Offline Bigsam302
« Reply #93 on: August 30, 2015, 07:46:52 PM »
Today I made some pretty good progress.  Yesterday there was a huge heat wave in SOCAL and I didn’t spend much time outside working on my bike.  I did end up baking my heads and they came out nicely.  One thing that I wish that I would have done was file down some of the imperfections in the casting and smoothed the fines out.  It looks great, but I think it would have looked even better.
I installed the base gasket, Cycle X Cam Chain Tensioner, and the cam chain slider.  Even though you can’t see it in the picture, I did install the dowels and the rubber gaskets at the base of the head studs.
I took out my 915cc Pistons and they look gorgeous.  It’s a shame that they are going to be hidden in my engine.  I also had the pistons coated.  That’s why the skirts are black.
Offline Bigsam302
« Reply #94 on: August 30, 2015, 07:49:32 PM »
After a lot of careful reading (and re-reading), I checked all of my piston ring gaps and everything looked fine.  I installed the piston rings and got started assembling the rest of my engine.
I managed to get the cylinder block on.  This was a pain in the butt!  Pistons 2 & 3 went in very easily, but 1 & 4 worked every bit of my patience.  I had to step away for a few minutes and try again.  Finally, I got the block installed.
Next the cylinder head went on without a problem.  I had to remove my steering damper to get it on, but I was able to put it back in its original location without an issue.  I really like the way the mount turned out.
I did run into one very big snag.  One of my cam shaft tower bolts was bent and stripped.  Luckily, it wasn’t in my cylinder head at the time.  I was trying to put a double nut on it so I could screw it into the head.  That’s when I noticed that it was in really bad shape.  So I had to stop there for the day.  I was able to find another one on ebay and I should have it by the end of next week.
Stay tuned for more updates!
Offline Bigsam302
« Reply #95 on: August 30, 2015, 08:11:17 PM »
Thanks for the advice Cal! I'll give it a shot. I was just going to check it again by trying to torque it again tomorrow.
Sent from my GT-I9505G using Tapatalk
« Reply #96 on: August 30, 2015, 08:11:34 PM »
Sexy-looking motor.  +1 on the re-torquing.
« Reply #97 on: August 30, 2015, 08:31:35 PM »
Now for the fun part - dialing in the cam. ;-)
Offline Bigsam302
« Reply #98 on: August 30, 2015, 09:04:31 PM »
Yeah, I'm not looking forward to that part!
Offline Konradwax
« Reply #99 on: September 01, 2015, 09:23:25 PM »
I want to see this bike run:)
