SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Replacement throttle
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Replacement throttle (Read 691 times)
stereosilence
Hot Shot
1975 CB550K
on:
November 04, 2014, 01:48:25 PM »
I have a busted, beat-up stock throttle that I would like to replace with my Yamaha R1 throttle. However, I can't swap in the OEM throttle cables and the Yamaha cables aren't the right lengths. Is there an easy way to use a non-stock throttle?
Logged
Build Thread:
http://forums.sohc4.net/index.php?topic=103534.msg1158525#msg1158525
bjbuchanan
Master
Re: Replacement throttle
Reply #1 on:
November 05, 2014, 07:58:16 PM »
Is the R1 throttle sleeve inside or exexternalthere are aftermarket throttle assemblys
Logged
70CB750
Labor omnia vincit improbus.
Really Old Timer ...
Northern Virginia
Reply #2 on:
November 06, 2014, 03:31:36 AM »
You can make your own - or alternate stock cables. I done it for R6 controls I use on my K0.
You cut the sleeve to the length and shorten the cable and solder new end on it.
Here is how:
http://classicmotorcycles.about.com/od/technicaltips/ss/How-To-Make-A-Motorcycle-Cable.htm
They even sell parts to make it easier.
Logged
ekpent
To many bikes-but lookin' for more
Reply #3 on:
November 06, 2014, 04:45:49 AM »
If its just a plastic throttle tube those are fairly cheap and easy to get.
Logged
bwaller
Reply #4 on:
November 06, 2014, 07:44:36 PM »
The R1 throttle tube is larger diameter and will "quicken" the throttle and needs longer inner cables. I modified a Motion Pro housing on my racebike to use an R1 tube. I found the Motion Pro cables (pull cable #01-0233, push # 01-0234) worked perfectly with my Mikuni smoothbores. I think they would work with Keihins as well.
Logged
stereosilence
Hot Shot
1975 CB550K
Reply #5 on:
November 07, 2014, 01:15:54 PM »
Will something like this work?
http://4into1.com/motion-pro-push-pull-throttle-black/
$15 is a drop in the bucket at this point (unfortunately). It would make my life a lot easier.
Logged
Build Thread:
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
