Author Topic: New 750 motor mount design..  (Read 4485 times)
« on: November 04, 2014, 03:41:21 PM »
Dreamt this up late this morning, had one made by coffee time..
Rough, quickie first off.. But shows how it will look..
 Let me know what you think.?
« Last Edit: November 04, 2014, 03:55:28 PM by 754 »
Offline brandEn
Re: New 750 motor mount design..
« Reply #1 on: November 04, 2014, 04:19:03 PM »
Looks awesome!
Offline edwardmorris
  • Youngish
« Reply #2 on: November 04, 2014, 04:28:47 PM »
That looks great Frank! Your timing is great too! I was just about to start asking around for a stock mount to replace this ugly thing that came with my K3. This will be perfect with finned covers.
  • Youngish
« Reply #3 on: November 04, 2014, 04:31:19 PM »
Also, if the ones above are the right size, dibs on the prototype!  ;D
Offline BPellerine
« Reply #4 on: November 04, 2014, 04:59:01 PM »
not sure but that looks like a mount off an auto on your bike ed,bill
1978 CB 750K ard and webers
another anfob
Offline willis
  • 1974 CB750
« Reply #5 on: November 04, 2014, 08:51:49 PM »
Those look great! How do we get our hands on a pair?
« Reply #6 on: November 04, 2014, 09:00:05 PM »
Bill I think he has a hiway peg mount..
Its been brought. To my attention that someone already makes the these, but I had no knowledge of that.
These ones are 5/8 or 3/4 thick..not sure about the other they look thinner.
 At this point, trying to see how much interest there is in these..
Offline Grabcon
« Reply #7 on: November 04, 2014, 09:05:28 PM »
754.
I like the concept of what you have done but my OCD has kicked in a bit. I have to ask. When mounted does the angle of the ribs in the mount end up parallel to the engine fins? This to me has always been an issue with finned points and clutch covers. I have never seen any finned covers manufactured with the fins lined up with the fins on the engine.
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
« Reply #8 on: November 04, 2014, 09:11:33 PM »
They are in line with engine.. 90 degrees to the front frame downtube.
Offline Whaleman
« Reply #9 on: November 05, 2014, 05:13:12 AM »
I like it. I seem to remember 30 years ago that road racers would double up this mount for more strength. Could you make this in steel to be chrome plated? Dan
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #10 on: November 05, 2014, 08:28:16 AM »
Looks awesome.
--Evan
1975 CB750K "Rhonda"
« Reply #11 on: November 05, 2014, 08:56:46 AM »
I prefer not to work with steel, for a few reasons.
  One being aluminun alloys can be left as is without plating. Plating can be a hassle.
 I think most bike parts should be lighter, and stronger than stock parts. In the case of  motormounts, they may weigh around the same as stock,  but be much stiffer.
 The lighter weight thing was important on the frame kits I built, I find it hard to add weight to a hopefully high performance bike, a step in the wrong direction it seems.
  • Youngish
« Reply #12 on: November 05, 2014, 08:59:07 AM »
Did you happen to whip up the other triangular mount Frank? The one that is slightly longer and has a hole in the center (hole doesn't need to be there). Would love to see how the fins look on that one...
« Reply #13 on: November 05, 2014, 09:16:32 AM »
Don't think the fins would work well with a Centre hole.
 But I have been thinking.. How about a cover that covers the whole stock setup, that is smooth (or finned) with radiused edges that is holding thru the center hole, mostly hidden on the backside..?
  • Youngish
« Reply #14 on: November 05, 2014, 11:52:58 AM »
That would also work, and eliminate the need to cut standard sized bolts a few mm to match the OEM odd lengths....
Offline dusterdude
« Reply #15 on: November 05, 2014, 04:05:23 PM »
Nice
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline bert96
  • past ride
« Reply #16 on: November 05, 2014, 05:38:47 PM »
I would buy it Frank.
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline Whaleman
« Reply #17 on: November 16, 2014, 02:17:01 PM »
754, Carpy makes a mount like this. $60.00 polished. Your looks thicker. Dan
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #18 on: November 16, 2014, 03:46:50 PM »
Looks great Frank but it's for the wrong bike.
« Reply #19 on: November 16, 2014, 03:53:20 PM »
Good idea, Frank. If 25 of us commit to buying, what would the price point be?
Offline jaguar
« Reply #20 on: November 16, 2014, 05:57:02 PM »
Very cool!
« Reply #21 on: November 16, 2014, 07:02:03 PM »
Probably. Around 60.00 with a brushed finish, they would be thick, like the other motor mounts I did..
Offline slikwilli420
  • Master of Disaster
« Reply #22 on: November 16, 2014, 07:32:02 PM »
You planning on making any rear mounts?  Still need one for my '76F.
« Reply #23 on: November 16, 2014, 07:46:12 PM »
Can't carve them out manually. At a rate I can make money on them unless I simplify. Them somewhat, which probably means. They won't straddle the frame mount holes. Plus the K and F, are two separate designs.
 However it looks like I may work with someone soon with a small CNC,  that may be good for that part.
 It's a smallish,  lowdollar  part that is small in numbers,  so it's hard to get them CNC,d without out a better grade lump of cash thrown at it..  So still may happen..
