Author Topic: CB 550k2 Queries  (Read 632 times)
Offline garyw
CB 550k2 Queries
« on: November 06, 2014, 01:44:15 PM »
Hi All, I have just joined the forum as my knowledge of the cb550 is limited.
Although I own other Honda's I need advice on the 550k2
This came into the Uk 2 years ago from Colorado and is very nice but after riding the bike I found handling terrible (wrong size tyres, American) and head bearings shot.
The bike also has a lovely flat spot when pulling away!!!
The previous owner has fitted a 400 handle bar cut out switch and run the cable outside the bars, He also opened up the switch casing so wiring would not be crushed.
I think I can repair this switch so that is not really a problem.
But the left Indicator switch is badly discoloured and on this bike it is the expensive rare switch, is this because the bike comes with a audible indicator siren.
Can I do away with this and use another model switch maybe 400.
Has anybody had similar problems.
Any feed back most welcome and thank you Gary.
Re: CB 550k2 Queries
« Reply #1 on: November 06, 2014, 05:02:12 PM »
Personally, I would buy a new proper control if I plan to keep the bike. If not, then get a cheap used one....
 http://www.ebay.com/itm/honda-cb550-500-750-gold-wing-74-76-left-control-switch-09435-/361068816540?pt=Motorcycles_Parts_Accessories&hash=item541160e89c&vxp=mtr
Audible system?
Offline garyw
« Reply #2 on: November 07, 2014, 06:18:40 AM »
Thanks Steve O for your reply.
Not sure what I'm going to do with the bike yet but always wanted one. I first went for a ride on one in the early 70s. (500) and after that I have always been a Honda man.
Do you think I should post my question on the tech part of the forum as I don't really want to keep the audible part. It looks to me my switch has 10 wires where the other models have 9 and 1 wire is for that audible device.
I have also seen many things on the engine flat spot, but beside a engine tune is there a common problem that causes this.
thanks again gary.
Offline flatlander
« Reply #3 on: November 07, 2014, 01:56:16 PM »
the 550 handles quite nicely so get some proper tyres, that should help. you may need to make sure the suspension is ok, as well.
replace that head bearing with a tapered one.
do the full 3k maintenance as described in the manual (see here, part 9: http://www.sohc4.net/cb550books/).
see if tuning everything properly improves your flat spot. the 550 is know to have a bit of a flat spot as per design, see here: http://forums.sohc4.net/index.php?topic=7401.msg67251#msg67251.
it should not be so extreme that it bogs you down, however. and you'll be using it from 5k rpm upwards if you ride it properly, anyway.
there should be a buzzer mounted behind the left fork ear which is meant to beep together with the turn signals. just unplug it and enjoy the peace and quiet.
