Author Topic: Engine stalls out after 10 minutes of driving!!  (Read 3639 times)
Offline Gesture
« on: November 06, 2014, 09:50:12 PM »
Well, I finally got the bike started first kick, and carbs have been cleaned and synced. Off for the initial exciting ride since purchased. By the way she is a 1974 CB550. Any rate, Ran beautifully, but after about 10 minutes she started stalling, and lurching like the  fuel was shut off. After sitting on the side of the road for 5 minutes, she started back up no worries.
TIP: If you POR 15 seal your gas tank and leave your gas cap on while swishing it around, the sealant will cover and plug your breather hole for the tank. As I was sitting on the side of the road for 5 minutes the tank had time to re-pressurize slowly. Simply drill a small hole in the seal cap under the chrome lid and it should be fine.
Everything I googled on this issue pointed me towards electrical/new battery, rectifier. Pshh just a drill bit.
I really hopes this barely technical post helps someone out.
Thanks
Ryan
Sooke, Canada
Re: Engine stalls out after 10 minutes of driving!!
« Reply #1 on: November 07, 2014, 03:40:26 AM »
Congratulations!  Got the bike on the road and also troubleshooted first issue - makes you feel like million bucks, doesn't it?
Pictures?
Offline Gesture
« Reply #2 on: November 20, 2014, 03:04:35 PM »
have only had the bike for about 2 months now, but here are some requested pictures. Please dont judge two harshly. New kid = no time for CB :(
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: November 20, 2014, 03:18:11 PM »
almost 42K!  How does the engine sound?  Noisy?   I've always liked white and black bikes, looks good...Larry
Offline Gesture
« Reply #4 on: November 20, 2014, 03:38:51 PM »
Sounds and ran great. What an experience riding such an old bike!! I say ran because she left me stranded on the side of the road today :( couple cylinders needed a break from firing. But thats all part of the game when bringing a bike back from the dead I spose!
Offline DWS
  • Treat others as you would like to be treated .
« Reply #5 on: December 27, 2014, 06:16:57 PM »
When mine did that, it was vapor locking, my gas cap was not venting correctly,  so i realized it, i losing the cap and on the why i went.
The gas cap rubber had swollen to much.
« Last Edit: December 27, 2014, 06:19:31 PM by DWS »
Always looking for friends.
78CB750F3
PD 42A with original breadbox
4 into 1
valves adjusted to .003 (intake and exhaust) ( as was suggested for cooling )
slow jets#35 Main #110
 turned out to 1.5 some paper work says 1.75
4800 feet altitude
78 Honda CB 750 F3 Restoring now(Almost done)
BSA MX 50 Next
BSA b50T Parts
Offline edwardmorris
  • Youngish
« Reply #6 on: January 07, 2015, 10:55:21 AM »
Have a pic of where exactly on the gas cap you had to drill?
Offline artistry06
« Reply #7 on: August 25, 2015, 12:12:29 AM »
Thanks
Ryan
Sooke, Canada
Geeze sounds just like the problem I had! I ended up bringing it to a local mechanic, had them redo the carbs only to find out that it couldn't start anymore...... So his suggestion was to redo the gaskets & found out that 8 of my arm rockers are worn along with the camshaft.... SMH!!!!!!!!!!!!!!! ARG!!!
