Author Topic: Rear axle spacer question  (Read 1584 times)
Offline Scott S
« on: November 10, 2014, 01:29:22 PM »
 I'm trying to mount my Henry Abe wheels to my Sweep The Floor bike. The swing arm I have is an F model swing arm.
 The H.A.'s use a K style brake backing plate. I have several axles and spacers here, but they're all from a K model. I can't get an accurate measurement of the F model spacer with it mounted to the bike (my OTHER bike), but it looks to be a couple of mm longer/wider.
 There are a couple of rear axles on eBay but I can't be 100% sure that they're actually F model axles/spacers.
 I posted an ad in the WANTED section, but would any of you have a spacer?
 If push comes to shove, would there be a problem with stacking a thick washer or two between the inside of the swing arm and the K spacer?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Re: Rear axle spacer question
« Reply #1 on: November 10, 2014, 02:28:39 PM »
Sounds like you got it figured out...yes the f spacer is longer.  It looks like the f is the assembled wheel, and you are holding the k spacer, right?  Pretty sure the backing plates are all the same, it's the f swingarm that is wider, requiring a longer spacer.  The f swingarm also uses different axle adjusters than the k, they might be slightly thinner.  I can't think of any reason why making up the difference with washers would hurt anything.  All this is from memory as I don't have any 550's on hand anymore.
Offline Scott S
« Reply #2 on: November 10, 2014, 02:30:20 PM »
 Yes, I have a 550F (pictured) and the bike I'm building is from spare parts (see my thread in the Projects forum, the STF2 Bike).
 The STF bike has an F swing arm and all the spacers I have are for K bikes.
'71 CB500 K0
'81 Yamaha XS650
« Reply #3 on: November 10, 2014, 02:33:44 PM »
Shouldn't be too hard to find that f spacer or whip something up.  Just take the back wheel off your f so you can measure.
« Reply #4 on: November 10, 2014, 03:20:53 PM »
The late axles have nut on the end, unlike  the early ones.
I think backing plate off 77/78 K pretty well hasbto fit right .
Offline Scott S
« Reply #5 on: November 10, 2014, 03:49:05 PM »
 I have that style of axle, too. I also have a late style backing plate but, unfortunately, the H.A. wheel take the early style backing plate.
 It looks like the F spacer is about 6.5 or 7 mm wider than the K model.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #6 on: November 11, 2014, 03:32:41 AM »
Without removing the axle from the 550F, the best measurement I can get is approx. 2" long, or about 51.7 - 52 mm.
 For comparison, the K spacer is about 45 mm. The F spacer is a little over 6 mm longer.
'71 CB500 K0
'81 Yamaha XS650
