Author Topic: CB750F gas tank - how can I tell if its sealed right?  (Read 468 times)
Offline Nayl
« on: November 11, 2014, 11:08:23 AM »
So I bought a 76 CB750F last summer, with the idea of doing a mild restoration and getting it on the road by next summer.  When I got the thing, its ran ok, but eventually got rougher and rougher and then stopped (this was over several weeks).  When I drained the tank, what came out had a strong orange/reddish tint to it, and I thought "uh-oh, rust."  The tank is lined with what I'm reasonably sure is Red Kote, and from what I've read, that can cause the discoloration I saw.  Before I go through the aggravation/expense of stripping out the old liner and relining, is there some simple, easy, foolproof method to determine if Ive got very tiny rust particles in my gas?
Re: CB750F gas tank - how can I tell if its sealed right?
« Reply #1 on: November 11, 2014, 12:19:43 PM »
MMO will also color fuel red/pink.
shake up your tank. drain it directly from the fuel tap into a mason jar.
let it sit for a while, and look for sediment in the bottom.
you'll know right away if your in-tank fuel filter is shot, and/or you still have debris in your tank.
Offline Nayl
« Reply #2 on: November 11, 2014, 04:00:04 PM »
Damn that seems obvious now that you say it.  Thanks!
« Reply #3 on: November 11, 2014, 05:21:47 PM »
Factory fuel filter
