Author Topic: 350F what is this part?? rubber wire pass through gasket for alternator  (Read 1918 times)
Offline Jayelwin
So the little rubber gasket thingy that is just above the number 1 on this picture. I am banging my head against the floor trying to think of what search terms to even use to find one. Mine turned to dust as it was so old and brittle and dry.
Of course it's not a numbered part. I'm hoping I can find one.
-Josh
Offline Jo3f1sh
  • Still don't have a jacket, even though I'm a
Re: 350F what is this part?? rubber wire pass through gasket for alternator
« Reply #1 on: November 11, 2014, 05:35:08 PM »
CMSNL simply lists it as the harness. Apparently it comes with that piece already attached.
Here's the best I could do: http://www.ebay.com/itm/1974-HONDA-CB350F1-CB350-F1-HM738-ENGINE-STATOR-WIRE-HARNESS-WIRING-/351071312662?pt=Motorcycles_Parts_Accessories&hash=item51bd7b1b16&vxp=mtr
1974 Honda CB350 Four
Build thread: http://forums.sohc4.net/index.php?topic=138848.0
Offline Jayelwin
« Reply #2 on: November 11, 2014, 06:07:53 PM »
Ugh, I'd hate to buy a whole new harness for that little piece of rubber.
Can't believe it's a part with no name.
Offline fmctm1sw
« Reply #3 on: November 11, 2014, 08:37:56 PM »
You might have to get creative on that one.  I don't recall ever seeing just that little piece.  I know what you mean, those are always manged....
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline MoMo
  • Ride like you're invisible
« Reply #4 on: November 11, 2014, 08:39:28 PM »
pm me I may have one in my parts bins...Larry
Offline HondanutRider
« Reply #5 on: November 12, 2014, 05:08:18 AM »
If you can't locate a replacement, I'd get creative and apply some black silicone sealant to mend/replace that rubber piece.  It must have been there to seal and hold the wires, and some liquid sealant could do the same when it solidifies.  Not sure of the location, but if its hided away then who but you would know the difference.
Offline Bodi
« Reply #6 on: November 12, 2014, 05:32:59 AM »
I bought a fairly big simple round grommet at an electronics store, then cut it and bent to to fit the wires and hole. Not perfect, but the hole doesn't have to be sealed - the area under the seal is basically open to the elements. The rubber is just to prevent chafing of the wire insulation, I think.
Offline MoMo
« Reply #7 on: November 12, 2014, 05:09:31 PM »
I agree-I always thought the purpose was to prevent chafing and prevent the starter wire from shorting to the frame...Larry
Offline Jayelwin
« Reply #8 on: November 13, 2014, 03:53:38 AM »
I think I might have to piece the grommet I have back together and reinforce it with some RTV.
Sent from my iPad using Tapatalk HD
Offline MoMo
« Reply #9 on: November 13, 2014, 07:11:58 AM »
I thought I had a spare alternator with the grommet but it is nowhere to be found...Larry
« Reply #10 on: November 13, 2014, 07:21:53 AM »
make your own out of some black foam rubber
