Author Topic: Frustration removing fork bolt  (Read 901 times)
Offline skyline223
    • willtuckermusic.com
« on: November 14, 2014, 12:47:00 PM »
I am trying to remove the right fork bolt (large chrome nut on triple tree) to change my fork oil and I am about to lose my mind. The bolt will unscrew about 1/4" and then it will not come out any farther. It will continue to turn with very little tension but will not unscrew any more. All threads that I have read talk about removing this bolts as if it is a very simple procedure.. so what am I missing?
Thanks
Will Tucker
willtuckermusic.com
Re: Frustration removing fork bolt
« Reply #1 on: November 14, 2014, 12:49:59 PM »
You have the front end elevateed to take weight off the nut?
Offline skyline223
« Reply #2 on: November 14, 2014, 12:52:39 PM »
Yes sir, front end is off the ground.
Will Tucker
willtuckermusic.com
Offline Maurice
« Reply #3 on: November 14, 2014, 01:11:56 PM »
Did you remove the spring? If so put it back in it helps keep the damper part from turning.
Even then it may turn. Borrow an impact wrench?
Offline skyline223
« Reply #4 on: November 14, 2014, 01:14:50 PM »
Spring is in place. I have tried using an impact wrench and basically I end up spinning the bolt at 6000 rpm with no avail...
Will Tucker
willtuckermusic.com
« Reply #5 on: November 14, 2014, 01:18:46 PM »
You can probably just pull/pry it out then...it is just hanging up on a tight o-ring.  Maurice, I think he is talking about the cap at the top of the fork tube and sounds like you are referring to the allen bolt at the bottom.
« Reply #6 on: November 14, 2014, 01:24:10 PM »
Like Sean said you have screwed it out of the thread zone and now it is just being held by a large o-ring. Get a grip on it with something and pull or pry that sucker outa there.
Offline skyline223
« Reply #7 on: November 14, 2014, 01:30:48 PM »
Not sure why that didn't come to mind... but that was it! Just needed to be firmly pulled. Thanks so much guys!!!!
Will Tucker
willtuckermusic.com
