Author Topic: 1977 CB550F Final Drive Flange Removal  (Read 947 times)
Offline dagersh
    • Photos
« on: November 14, 2014, 02:58:40 PM »
Hi Guys,
Just wondering - is the 550's Final Drive Flange a "Press Fit"?  Should I be able to pry it out using the rear sprocket?
I have the bearings, spacers and retainers all out already.
Thanks!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
Re: 1977 CB550F Final Drive Flange Removal
« Reply #1 on: November 14, 2014, 03:57:44 PM »
So,
Looking at the rear hub, I see what looks like stake marks on the outside of the piece where the bearing retainer screws in.  Do I need to drill those out and back out that middle piece?  The schematics don't show that, and I am getting confused.
Thanks,
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
« Reply #2 on: November 14, 2014, 04:37:48 PM »
Here is where I am....
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
« Reply #3 on: November 14, 2014, 04:45:20 PM »
with the retaining ring out removed like you have it should just come out,they can be stubborn if they haven't been apart for a few years.
Offline dagersh
    • Photos
« Reply #4 on: November 14, 2014, 05:02:54 PM »
Dave,
I was hoping you would chime in!
Its pretty stubborn - a complete bike, which i got running well before tearing into it.
What should I be doing to get the hub apart?  I want to PC everything for the rebuild.  The rubbers are definitely in good shape...
Just cannot get the flange apart.
Thanks Bro!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
« Reply #5 on: November 14, 2014, 05:12:53 PM »
try wd40/crc/pb blaster between its hub,probably rusty in there,try carefully knocking through the holes on the other side in the brake drum side,not too hard,from side to side it might wiggle out.
Offline dagersh
    • Photos
« Reply #6 on: November 14, 2014, 05:53:44 PM »
Thanks Dave!
I will get something with a blunt head and some good penetrant and heat and get this bad boy apart.
It feels REALLY GOOD to get back at this bike!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
« Reply #7 on: November 17, 2014, 08:37:14 AM »
Hi Guys,
Got it apart.  Just what Dr. Dave prescribed.  Although pretty clean inside a healthy dose of Deep Creep, Map Gas and a Hammer and Brass drift on the rubbers and she slowly released.
Now I can clean up the hub, PC it and polish the flange, although after cleaning it up, that might not even be necessary as the caked on decades of lube protected the hell out of the factory "bright" finish.
So to recap - a 1/4" bit is required to drill out the stakes on the bearing retainer.  It seems huge, but whn you look at the "access ports" on the face of the retainer, it makes sense.  I just did each one a little bit, applied heat and penetrant, and carefully knocked the retainer CLOCKWISE to see if it would release and move.  I repeated until it did.  I was able to remove the retainer with no damage to its, or the flange's fine threads.  I am able to screw the retainer in smoothly for the rebuild.
As always, thank you for help and wise advice.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
« Reply #8 on: November 17, 2014, 11:35:04 AM »
I never restake them either,because of the wheel vs the thread direction youd be unlucky if one came loose.
Offline dagersh
    • Photos
« Reply #9 on: November 17, 2014, 12:00:22 PM »
Dr. Dave,
Thanks, that was going to be a question later on.
I think some blue threadlock to be safe, as I will be seling this bike when its done.
Thanks!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
« Reply #10 on: November 17, 2014, 07:03:02 PM »
thread lock is fine,just a dab,even though it looks like itll undo from rotation itll hold,i aint exactly a doctor either
« Last Edit: November 17, 2014, 08:21:30 PM by dave500 »
Offline dagersh
    • Photos
« Reply #11 on: November 18, 2014, 12:56:12 PM »
When it comes to CB's....  you are!
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
« Reply #12 on: November 18, 2014, 04:28:25 PM »
maybe a witch doctor!
