Author Topic: Hey 550 guys - DCC coils ?  (Read 768 times)
Offline greenjeans
  • 1972 CB750K2
« on: November 16, 2014, 08:55:51 AM »
I usually play with 750s, but I'm building up a 550 for a buddy of mine.   Sat outside for a very long time, so the plug wires coming off the coils are hard as a frozen rope, loose at the actual coil and cut too short to use.
I had always assumed that the coils for 750s and 550s were the same.  After reading and looking a bit this morning, I've found that they are different part numbers.   Something about the internal windings - over my head.
I've used repop coils from Dime City on my CB750s with good success.   5k coils with 5k plug caps.
These:   http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-electronic-ignition-parts-cb750k-12-volt-ignition-coil-38-2019.html
To me it seems like the 550 likes 5 ohm coils with 5 ohm plug caps -  Caps: VB05F & XB05F
Any of you 550 guys running those on your 550 ?   If not, what are you using ?
« Last Edit: November 16, 2014, 09:08:55 AM by greenjeans »
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=7fdo1ajtnb8kpj1n2lpa7cgoj7&/topic,60973.0.html
Re: Hey 550 guys - DCC coils ?
« Reply #1 on: November 16, 2014, 09:50:50 AM »
i got the same from somone in england...they are crap...in vet kondisions i hear hov the sparks jumps aut of the vhite backside..and over to the metal frame bolts...and the bike run at 2/3 cylenders...
in dry veather it ran better..but not perfekt
i endet up use some old coils from a 400 four....cut in to the veld point and solder nev vire on
but all others then this coils vill do the job...
i hate all this v-w.... vords
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #2 on: November 16, 2014, 11:01:04 AM »
Apperantly 3 ohm coils over tax the charging system on 550's so 5 ohm for me.
I'm using Dyna coils and they work great.
Offline C5paul
    • C5 Performance
« Reply #3 on: November 16, 2014, 02:20:04 PM »
If you want to upgrade the entire system I've got Section Bobbin coils and a sweet optical ignition that works awesome on 550 engines.
The coils are rated at 120,000 volts which is about 4 times the rating of a standard coil.
PM me if you want. I'm not trying to spam you, just offer an option.
