Author Topic: Dual throttle cables replaced by one  (Read 2023 times)
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« on: October 04, 2006, 01:52:18 PM »
I haven't got the 650 in front of me to help me out, so here's the question.
Is the return spring on the carbs strong enough to close the throttle if I were to convert from the dual throttle cables to a single cable set-up? I want to replace the oxidised, and generally manky looking switch gear on the bike with some nice old plain metal ones, which will polish up nicely. That means losing the 'return' cable.
I appreciate that the second (closing) cable is a kind of safety back-up and I would lose that.
Thanks in advance for input.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline Fiend
Re: Dual throttle cables replaced by one
« Reply #1 on: October 04, 2006, 01:58:34 PM »
I think it would be plenty strong.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: October 04, 2006, 02:02:26 PM »
I agree. The early 750's only had one cable and I can tell you it is strong enough to give your wrist a workout after a couple of hours. Just my opinion, I think it (second cable) was added in case of a spring failure, or more likely folks not maintaining the the cables properly.
Offline nickjtc
« Reply #3 on: October 04, 2006, 03:00:05 PM »
Thanks Fiend and Bob. I kinda figured that that is the case. eBay here I come.
1977 Suzuki GS750
Offline martini
« Reply #4 on: October 04, 2006, 03:04:32 PM »
I'm running a 750k0 with carbs off a 72 which feature push/pull double cable set up. The K0 however was only designed for one cable so thats how I've been running with it and haven't had a problem.
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« Reply #5 on: October 05, 2006, 09:10:04 AM »
I have two K0's with later carbs and only one cable...works fine.
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline nickjtc
« Reply #6 on: October 05, 2006, 10:41:10 AM »
Thanks for the feedback, one and all. Just snagged me a pair of old CL175 switchgear which will polish up nicely and look good on Sophie.
1977 Suzuki GS750
Offline mrbreeze
  • Not your average
« Reply #7 on: October 05, 2006, 10:51:10 AM »
I'm runnin one cable with no problems. That return spring seems to be stout enough to hold up to the job.
MEMBER # 257
Offline IndianRider
« Reply #8 on: December 21, 2006, 06:07:02 AM »
how do you reinstall the stout return cable ?? i had to unclip (un-tension) mine so i could get the slides to open and move freely while cleaning the carbs without disassembling the rack ... its a b**** to get back on unless i am trying to hook the ends to the wrong places  ???..where should the 2 ends hook on to ? any pics and tips would be appreciated .. thanks ..  ;D
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« Reply #9 on: December 21, 2006, 06:30:48 AM »
Link to exploded diagrams, check out the "CarburetorAssyLink" diagram, but it doesn't really show where it connects up to...
http://www.crotchrocket.com/fiche_section_detail.asp?category=Motorcycles&make=Honda&year=1978&fveh=2993
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline IndianRider
« Reply #10 on: December 21, 2006, 06:39:45 AM »
thanks .. i already checked it out and it doesnt help .. i made a mental note when i unhooked the ends of the spring, but it looks like it has to be wound real hard to hook the ends back to where they are supposed to be ..
i know the right (outer spring hook end) goes onto the throttle rocker shaft (or what ever its called) but the left hook (towards carb # 3) was hooked on to the rear side of carb # 3 ..this didnt seem right as i expected it to hook to a metal loop or small metal post ...
« Reply #11 on: December 21, 2006, 08:08:12 AM »
Reason for the second cable is that shoould the spring break, which has happened, your engine just dont slow down.
Original reason given by honda for changing carbs was it was possible to get an airflow situation where, on the 4 into 1 cable set up, the slides didnt come down--not sure if thats the real reason or not, personaly i think they got fed up of dealers/customers #$%*in about time involved in carb setting with the 4 into 1
Offline dusterdude
« Reply #12 on: December 21, 2006, 08:56:19 AM »
it damn sure is on mine
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
