Author Topic: XADO Revitalizant??  (Read 952 times)
Offline mihai.i
  • Sorry for my english!
XADO Revitalizant??
« on: November 18, 2014, 10:04:32 AM »
Hi guys!
I just saw on local forum in Romania a product called XADO Revitalizant EX 120, that they say is really good for your engine  :-\, restores worn surface of engine cylinders, eliminates microcracks and scratches, increases and levels compression in cylinders and other stuff like this...
quote
Restores worn surface of engine cylinders, eliminates microcracks and scratches
Increases and levels compression in cylinders
Protects friction surfaces against wear
Reduces fuel consumption considerably
Restores engine capacity up to factory values
Increases service life of an engine by 3 times
Decreases the level of toxic components in exhaust gases
Decreases noise and vibration level
More details here: http://xado.us/revitalizants/ex120/revitalizant-ex120-motor-equipment
What is about this product?
Do you even hear of it?
Honda Cb550k 1978
Offline vames
Re: XADO Revitalizant??
« Reply #1 on: November 18, 2014, 10:43:23 AM »
Can't comment on whether an additive could actually do all those things (probably not). But I do think there is one they could add to the list: "Destroys the functionality of your wet clutch"
Offline MiGhost
  • What was that about being an
« Reply #2 on: November 18, 2014, 12:59:10 PM »
It might work temporarily as it fills the voids with some form of material but, it will wear back out agian. Not sure if it is still availabe in the US, but there was something similar marketed as an oil supplement, engine restorer. I believe it was called CDR.
It had to be added to every oil change. Once you stopped using it. The engine quickly return to its worn out condition.
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
