Author Topic: Best option for replacing OEM spoke nipple?  (Read 1412 times)
Offline gregripko
« on: November 18, 2014, 12:49:11 PM »
Cb550k 76
The nipple got pretty rounded off during its life making adjustments pretty impossible..... Are these a generic item? Or will I have to hunt for them? Have the tire off so it would be nice to replace now... (Rear wheel)
Offline Old Scrambler
Re: Best option for replacing OEM spoke nipple?
« Reply #1 on: November 18, 2014, 01:32:03 PM »
Very generic to the 68 and newer 'big-bike' models................some variation in the color of the yellow zinc.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline gregripko
« Reply #2 on: November 18, 2014, 03:28:02 PM »
Ok so I can't get the spoke nipple off :/
Ugh..... It's super rusted on the nipple part..... Is it possible to just cut the spoke and it'll come out? Will it be hard to replace the one spoke? (Do I have to remove other spokes to replace it?)
Also.... Cb550 has two different spokes on the rear.... A and B..... Which is the inside and which is the outside? This one happens to connect in the inside rather than outside
Offline gregripko
« Reply #3 on: November 18, 2014, 04:51:56 PM »
Ok so I was forced to cut spoke.... Is there a trick to replacing them? Seems like other spokes would be in the way
Offline Vinhead1957
« Reply #4 on: November 18, 2014, 05:06:16 PM »
No trick just make sure you have the right one . There are inside and outside ones they have different heads. Be careful not to scratch the rim.
Offline gregripko
« Reply #5 on: November 18, 2014, 05:21:33 PM »
I've never replaced a spoke... I guess I'm confused... I assume it's like threading a needle with the screw side going through the hub first but it'll run into the other spokes :/
My guess is that I'll have to remove all the spokes in order to install this spoke... (Hope isn't the case)
« Last Edit: November 18, 2014, 05:25:29 PM by gregripko »
Offline Vinhead1957
« Reply #6 on: November 18, 2014, 05:45:01 PM »
No just the one, with a little bending.
Offline gregripko
« Reply #7 on: November 18, 2014, 06:09:31 PM »
The inner ones would have to bend tremendously
Offline goldarrow
  • one day, i'll be an
« Reply #8 on: November 18, 2014, 06:13:51 PM »
Use bolt cutter and cut off old spoke
CB550 K0
Offline gregripko
« Reply #9 on: November 18, 2014, 06:25:19 PM »
I removed it already....just figuring out the best approach to lacing the one without having to remove all of the spokes as it's an inner spoke
Offline heyitsrama
« Reply #10 on: November 18, 2014, 07:13:24 PM »
You can flex the spoke to a certain extent to have it fit in, but the inside ones are a pain in the ass, at least you removed it. heard about stories where the spoke shoots into the inner rubber. how many spokes do you really need?  ;D ;D ;D ;D
I have an old set of nipples, and spokes for a cb500 somewhere, lemme know if you need some?
_____________________________________________________________________________
72' cb500
I can't believe it's not butter.
Offline gregripko
« Reply #11 on: November 18, 2014, 07:22:18 PM »
I ordered a couple spokes already and hopefully I don't have issues with any others.... Yes after examining the wheels I wish an outer one would have been the issue rather than the inner....
Feel like I may be able to take off a couple to have it fit without bending it too much but def going. To avoid forcing stuff
Offline Maurice
« Reply #12 on: November 19, 2014, 06:58:07 AM »
There is one particular spoke (well, one kind) that could cause trouble because another spoke is in the way... I forget which one sorry, but you may have encountered that one. If that is the case all it takes is removing the spoke that is in the way. In other words, to install that one spoke you need to remove another one.
Sounds confusing but when you get there you'll understand.
This begs the question, if that one nipple was in such a bad shape and rusted, what about the other spokes?
Offline gregripko
« Reply #13 on: November 19, 2014, 08:09:26 AM »
The other ones seem ok.... It appears at some point moisture got into the rim and most likely settled to its lowest point and rusted... The nipple was smoothed out so a po must have encountered it but neglected to address the issue leaving one spoke inadjustable
