Author Topic: Putting bearings, races etc in the freezer before installing - T/F?  (Read 1115 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
I was reading somewhere the other day where someone had posted some numbers regarding the shrinkage of certain metals when frozen, and their argument was that the shrinkage wasn't enough to actually make it easier to install certain parts. Further, he argued, if you touch them with bare hands while installing they are no longer frozen; so that even if it would've helped you, now it won't.
I have always put bearings & races in the freezer prior to installation; but I can't say whether or not it has made the process any easier. Can someone who's knowledgeable about this kinda thing chime in here? Looking for facts here, not opinions thx
Offline Vinhead1957
Re: Putting bearings, races etc in the freezer before installing - T/F?
« Reply #1 on: November 18, 2014, 03:22:21 PM »
No facts but I practice that also and never had a problem
« Reply #2 on: November 18, 2014, 04:02:29 PM »
Here's some sample numbers from valve guides I recently installed (bronze type):
Valve guides measurements were taken at the middle of the installed portion of the shank, on an 85 degree summer day, as the 'baseline' value.
Left in freezer for 30 minutes: shrank OD .0003" to almost .0004" (this freezer is -20 degrees F).
Left in freezer just 10 minutes: same as above
Freeze-spray applied for 2-3 second blast: shrank .0001-.0002" tops.
Head holes (for the guides) were measured in the shade at 85 degrees, then the head was set in the hot Colorado sun for 30 minutes (too hot to touch with bare hands afterward).
Holes grew about .0001" to slightly over that, but not .0002".
Put head in oven at 250 degrees for 15 minutes: Holes grew .0003" on average.
So...if you were installing cold, frozen valve guides into a hot, oven-baked head, the extra clearance gained would be about .0004" to .0007" overall. While this doesn't sound like much, when installing a brass guide it is enough difference to prevent the guide (soft bronze) from distorting. If these guides are simply driven into the head holes like we use to do with Honda's cast-iron ones, they tend to distort (misalign) and require more machine work to make the valve seats seal like they should.
If you are installing steering head bearings, they will shrink a little more than these numbers because they are larger. And, it does help to install the races into the steering head, especially if you have the head sitting out in the summer sun. Grease 'em first, in any case.
« Reply #3 on: November 18, 2014, 04:38:18 PM »
 It clearly makes a difference. Someone is talking out of their, er, field of expertise.
Offline cb650
« Reply #4 on: November 18, 2014, 05:23:04 PM »
OH NO Now you did it!!!!!!!   ;D
« Reply #5 on: November 18, 2014, 05:42:19 PM »
Gears are installed on shafts using that process.  When i did my wheel bearings. Things literally fell into place.
Offline taggat
« Reply #6 on: November 19, 2014, 02:09:07 PM »
You should tell him hes right and your wrong. lol
66 TR650, 75 cb750ss, 78 XS650S, 12 Triumph Speedmaster
Ton-Up Indianapolis!
There's just something about twins....
Keep your wheel's between the ditches and the smokies off your britches!
I like my women like my motorcycle's, fast, dirty and cheap.
Bikes for sale, 75 cb750ss, 75 xs650, 76 cb360, 78 cb750ss, 78 xs650, 78 cb550, 81 cb450, 81 xs400
