Author Topic: flasher relay,will this work  (Read 525 times)
Offline heymak
« on: November 18, 2014, 03:05:37 PM »
hi , I got  this flasher unit on ebay will it work ,
terminals marked L P and X ?
just an old 2 pin unit on my bike at the mo,
any help appreciated
« Last Edit: November 18, 2014, 03:07:20 PM by heymak »
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
Re: flasher relay,will this work
« Reply #1 on: November 18, 2014, 03:56:30 PM »
It would help to know what bike ::)
The original two-pin has one wire for supply and one wire for the switch. The three-pin electronic uses these and also calls for an earth (at least the one on mine does).
On the 750 (and I think 550) Honda supplied a spare earth wire (green under the left side panel) with the same female flag connector as those on the two-pin flasher, so I've always assumed the purpose of that earth wire was to give you the option of fitting a three-pin unit. Or maybe the loom is standardised and different spec bikes have the three-pin already? I don't know.
Anyway, the three-pin I used has these markings -
Terminal 49 to Supply  Terminal 49a to indicator switch. Terminal 31 to Earth.
Easy to fit, once you work out which of your two wires are which (black is supply and grey is switch IIRC), with the spare earth going to 31.
The one you have does not appear to call for earth, this is what I found on the interweb -
Terminal P to Vehicle Warning Lamp.  Terminal X to supply.  Terminal L to Indicator Switch.
I have no idea how you would, or could get that to work as you don't have a convenient wire available for the P terminal. My understanding of electrics is pretty basic though, so hopefully others will set you straight. :)
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline heyitsrama
« Reply #2 on: November 18, 2014, 07:18:48 PM »
The flasher that I bought the other night is a LittleFuse 460* it has a
+ (positive? - Black)
- (Ground - Green)
L (Switch - Gray?cb500)
I was also confused about this, and was trying to look online for a pinout, but stumbled upon this, https://groups.google.com/forum/#!msg/rec.autos.makers.vw.aircooled/gVnWkheOCT4/dnNFDtvdnbAJ
_____________________________________________________________________________
72' cb500
I can't believe it's not butter.
Offline heymak
« Reply #3 on: November 19, 2014, 05:28:51 PM »
thanks for the info guys cheers
