SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Just bought a used '72 cb750 engine. Opened the oil pan and found some gunk.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Just bought a used '72 cb750 engine. Opened the oil pan and found some gunk. (Read 557 times)
specialone70
Full Member
on:
November 22, 2014, 11:11:26 PM »
Looks like some silicone and metal (some was magnetic, some was not). The engine supposedly ran and has 20,000 miles (according to the guy I bought it from) and I paid $150. How'd I do? Do you fellas think it's serious?
Logged
seanbarney41
not really that much younger than an
Really Old Timer ...
Re: Just bought a used '72 cb750 engine. Opened the oil pan and found some gunk.
Reply #1 on:
November 23, 2014, 12:15:07 AM »
looks fairly typical with these. As long as the cam gets oil, it will keep running. I would just run it until it breaks, then buy another for $150.
Logged
specialone70
Full Member
Reply #2 on:
November 23, 2014, 12:23:05 AM »
I checked in the valve access ports and didn't see any soot (like I found in the engine it's replacing, which wasn't getting oil to one of the plain bearings) so I think we're good there. Thanks for the reassurance!
Logged
seanbarney41
Reply #3 on:
November 23, 2014, 12:28:37 AM »
Peek in the exhaust side tappet covers while it's running, if oil splashes out, your good to go for a while...basic tune up #$%* will totally help too
Logged
PeWe
Bike almost back to the 70's 2015
Reply #4 on:
November 23, 2014, 12:29:22 AM »
Rubber from chain tensioners. I think these engines must be opened completely and replace chains and tensioners, the rubber wheels become hard and grinds into small pieces. Primary chains and cam chain.
Check if all clutch plates are intact. The alu like flakes can be clutch fiber plates. I have seen that in my engine.
Edit: Cam sprocket bolts can touch head if too long causing alu flakes. Mine were very close so I filed them shorter
Last Edit: November 24, 2014, 03:28:19 AM by PeWe
Logged
CB750 K6-76 970cc (Earlier 1005cc JMR Billet block on the shelf waiting for a comeback)
CB750 K2 -1975 build thread
chewbacca5000
I polish covers!
Old Timer
Reply #5 on:
November 23, 2014, 07:03:02 AM »
Get a magnet and see if anything is attracted to it. Does not look too bad to me. Clean screen and pan well.
Logged
http://forums.sohc4.net/index.php/topic,169281.0.html
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
