Author Topic: Front Wheel Axel Nut Removal  (Read 3651 times)
Offline cgarbe
Re: Front Wheel Axel Nut Removal
« Reply #25 on: November 30, 2014, 09:37:15 AM »
Thanks for the advice guys...I do have a pin wrench that I tried to use but I wasn't getting any movement from the nut. I drilled out the stakes, sprayed PB Blaster on the nut every few hours for 2 days and let it soak in, tried the pin wrench and the nut still wouldn't move...so then I took out the punch and hammer and got it out. I know it isn't the proper way to remove it from the wheel hub but it was the only way. Now onto the bearings.
1975 Honda CB400F
1978 Honda CB750F
